2010/2011 ecu compatibility - BMW S1000RR Forums: BMW Sportbike Forum
Old 01-09-2012, 12:38 AM   #1 (permalink)
Default 2010/2011 ecu compatibility
having sum issues wanted to know if the ecu and ignition from the 2011 will work with the 2010 was working on the bikes earlier today me a a friend have s1000 rr's and i accidentally plugged in his ecu and ignition when we were rapping up and the bike would turn over but she would not start, for a minute thought i'd have 2 take advantage of that warranty ; ). anyway my question is i believe the 10' rr has 3 modes race, rain etc while the 11' rr has 4 modes including slick but for future reference just in case anyone has to get a new ecu on ebay or used whatever the situation it can be cleared up on here if there are any differences so they don't get stuck with a ecu they cannot use. also when u plugged in my original ecu she cut right on, thank you in advance 4 any info on the matter and i hope this can help anyone who runs into this problem..
504boy is online now   Reply With Quote
Old 01-09-2012, 09:07 AM   #2 (permalink)
Both have the same 4 modes.... Rain, Sport, Race, Slick
Old 01-09-2012, 10:41 AM   #3 (permalink)
are u sure im almost positive i didnt see a slick mode on my 10' and any info on the ecu compatibility??
Old 01-09-2012, 11:43 AM   #4 (permalink)
They are the same. If one bike has a drop sensor and the other doesn't that can cause malfunction. Swapping ECU's is not recommended even for testing purposes. Possible mileage transfers can happen if you don't also swap instrument clusters at the same time--would have to be ridden to have an effect the mileage, just sitting and starting won't effect it.
Swapping ECUs often necessitate "reseting adaptation values" in order for the ECU to work correctly on the non-original bike. Not always necessary but usually is.
If you don't have SLICK mode on the '10 then it doesn't have the SLICK plug installed.
Why are you swapping them anyways?
Old 01-09-2012, 11:59 AM   #5 (permalink)
What Viper ^^^ said.... My '10 has had Slick mode since it hit land in January/February of 2010.
Old 01-09-2012, 12:04 PM   #6 (permalink)
DrIoannis's Avatar
There is a Slick mode in 2010 models please read your manual!
This is the 3rd topic with the same question...
