Hi there guys, I'm kinda new to your forum and i am having a small issue with my beemer.
Well everything started a month ago, i purchased some folding levers and fitted them on the bike.So when i went for ride the bike did a really weird thing,While in low speed like 1st or 2nd and low revs like 2k to 4k when i was closing the throttle something with the iddle wasn't going right.I mean it was about to die and sometimes it did.
So my first guess was the small switch under the clutch lever (and since i have shift assist i knew something was wrong). So i adjusted the metal plate to hit the switch at aproximatly 44 to 50 mm as i read somewhere.I had no luck with it so i checked the air filter (that was my second guess).Nothing there either
the air filter was good as new.
So my next guess was the injection and since i have 10k kmh on the bike i bought today an injection cleaner fluid and went for a ride.It seemed better so i pussed a bit , i've started to accelarate and braking hard and fast, and in first gear it started backfiring in really low revs like 2k to 3k and then it died .There wasn't any flames out of the slip on but i could hear' em in the pipes.It sounded more like a snorring actually but it was backfires in the pipes,Really weird :S.
I don't know if this has anything to do with the battery since i have xenons on the bike and i still haven't check the battery.Btw the bike iddles great just like a clock and this thing occurs only when i pull the clutch and i already have gear on the bike and the rev's drop.
i Have stock exaust and an akra slip on and the oem air filter.
Any suggestions ? I could really use some
