I've done it. It's really a feel thing.
When you squeeze the lever with the normal set-up the fluid has to make it's way through a lot of brake line and of course the ABS accumulator which I guess has all kinds of plungers and diaphragms inside. It basically feels, to me, like having really rubbish rubber hoses rather than braided lines.
If you have the race ECU you can go ahead and remove the pump (replace with alpha racing plate), after removing the lines this is just one more small step. I don't have the race ECU (yet! :P) so the pump needs to stay but be blanked off. If any one needs the details on this then feel free to send me a PM.
I'd say it's most useful if you run really aggressive pads and/or you like to run deeeep into the corner on the brake, then you need as much feel as you can get. That said, it gives the rear brake a ton more power.
