Rear Sprocket VS Stock Chain Length - BMW S1000RR Forums: BMW Sportbike Forum
Old 11-28-2011, 11:32 PM   #1 (permalink)
DB Cooper's Avatar
Default Rear Sprocket VS Stock Chain Length
How many teeth can I add to the rear before I need a longer chain? Can I get away with two teeth before a new chain is required?
DB Cooper is offline   Reply With Quote
Old 11-28-2011, 11:47 PM   #2 (permalink)
senator8's Avatar
I fitted +2 with stock chain no problem
senator8 is offline   Reply With Quote
Old 11-28-2011, 11:50 PM   #3 (permalink)
Triple Threat's Avatar
You can also go down -1 up front (from 17t down to 16t) which is the same as adding just under 3 teeth out back. Some people do both.
Hope this helps,
Triple
2010 BMW S1000RR
2009 Aprilia Dorsoduro
2006 BMW R1200RT
Old 11-28-2011, 11:52 PM   #4 (permalink)
DB Cooper's Avatar
What do you think about the + 2 on the back?
Old 11-29-2011, 12:07 AM   #5 (permalink)
senator8's Avatar
I Liked it a lot, was a great improvement so I went -1 in the front as well.
now have -1 & +1 (16 - 45) this combo suits me perfectly.
Old 11-29-2011, 09:43 AM   #6 (permalink)
Start out with a -1 on the front. Try it out first. I think you'll like it a lot. It is just shy of adding three teeth to the rear, I think it is equivalent to +2.6 in the rear. Stock chain length will be fine. It is also easier to do (although the rear isn't too hard either). And it is cheaper.
Then if you still want a little more get up and go after you do that, add two to the rear. So you'd end up at -1,+2.
I've been running this for over a year and it is a great mod. Also puts the RPMs for in town driving in a more manageable area.
EDIT: I'd add that the stock chain length is also fine for a -1,+2
Old 11-29-2011, 11:32 AM   #7 (permalink)
DB Cooper's Avatar
Thanks for the input guys. I'm going to do the 16 tooth on the front and fit the BMC air filter this winter as part of winter mods. I also will be winter modding my 600RR, installing an Annitori quick shifter and removing the Pair valve and putting in a K&N air filter on that bike. I also will be installing the motivation weighted barends. Did this on the S1K and it does make a big difference.
