Need help on Suspension Set Up. - BMW S1000RR Forums: BMW Sportbike Forum
Old 08-25-2011, 11:15 AM   #1 (permalink)
Default Need help on Suspension Set Up.
Just bought my S1K about 3 weeks ago, the set up its still how I got it from the dealer.
I wonder what I'm missing(confort and safety) not having it properly adjusted.
So if anyone here had yours professionally adjusted or have the knowledge on how to make it right, I'll appreciate your help.
I'm 6 ft and 172 pounds.
Never ride on the track. Skill is basic, just ride on the weekends.
Thank you.
Rubikan is offline   Reply With Quote
Old 08-25-2011, 11:53 AM   #2 (permalink)
AMRRA12's Avatar
Set sag 40mm front from full extended
Rear 35mm from full extended
Turn front rebound to 9 and have fun
AMRRA Open SS Expert #1
Sponsors:
Lithia Motors
Snap-on tools
Big Bobs Flooring
Mat-Su Tattoo
Old 08-25-2011, 12:07 PM   #3 (permalink)
moto27's Avatar
Hi, I may be wrong in this quote, but........I have been told to set the front sag between 30 - 35 and the rear between 35 - 40??
moto27 is offline   Reply With Quote
Old 08-25-2011, 02:41 PM   #4 (permalink)
AMRRA12's Avatar
No IMO 40mm is too much in the rear, some tunners only like 10 to 20 in the rear i have alway like
race:
front - 30-35
rear- 25-30
street:
front - 35-40
rear - 25-30
Sponsors:
Lithia Motors
Snap-on tools
Big Bobs Flooring
Mat-Su Tattoo
Old 08-25-2011, 11:54 PM   #5 (permalink)
jhockey18aa's Avatar
Just get it setup by your local moto shop. I got my stock suspension dialed in today for a special price of "FREE"!
Feels like a new bike! Cant wait to tweak it on track...
Sometimes its who you know, not what you know!
2006 ZX6R (my first love)
2010 BruteForce 750I
2011 BMW 328XI
2011 BMW S1K Yellow
Zero Gravity Corsa Windscreen (light smoke)
Yoshiframe sliders
RG mirror block offs
GB case savers
Arrow s/o
CRG lvrs
4878 miles and counting...
jhockey18aa is offline   Reply With Quote
Old 08-26-2011, 07:30 AM   #6 (permalink)
JBuchanan's Avatar
What do you recommend for the compression in the front? How about rebound and compression in the rear?
Jay Buchanan
JBuchanan is offline   Reply With Quote
Old 08-26-2011, 07:44 AM   #7 (permalink)
moto27's Avatar
I have this from good authority, albeit Im 190lbs,
forks to line #2 or 3. Set preload at the middle, compression on 6 and rebound on 8. Leave the shock in the low mount, high speed 1, low speed 3, rebound 8
Old 08-26-2011, 01:20 PM   #8 (permalink)
AMRRA12's Avatar
Guys there are no magic #s every one rides at there own skill level and has there own style of riding
All you can really do i's set sag, base line your comp and rebound and go from there
a good Base line i's
Set comp and rebound to the middle
Except on front rebound (we all know how off it is)
Set that at 9
Sponsors:
Lithia Motors
Snap-on tools
Big Bobs Flooring
Mat-Su Tattoo
Old 08-26-2011, 05:53 PM   #9 (permalink)
Set that at 9
+1 for what AMRRA said.
"Setting preload at the middle" doesn't have any real meaning unless it's in the context of a suspension developer saying "start with 6 turns of preload for your weight and these (xx rate) springs, which would be based on his knowledge of the specific bike/fork/spring rate/rider/use combo.
40mm fork sag is a good starting point for a street-use bike with 120mm of front travel, and which has a short top-out spring (which the BMW does have). On an RC51, for comparison, the sag setting might be a little larger due to very long top-out springs.
On a bike with Ohlins forks, the target sag might be 40mm on a racebike due to increase travel available (130mm) and the fact that the Ohlins forks use longer, softer top-out springs. If you wind in a bunch of preload to try for 35mm of sag, you might override the top-out springs with main spring tension and you end up ruining the top-stroke ride quality (when the bike is accelerating). With the Ohlins forks, it's better to keep the ideal sag and preload and to correct with spring selection.
When selecting your base sag target, you start by factoring use - more sag to allow for dips/potholes which require a larger amount of extension to handle correctly, and you also want an appropriate corresponding rear sag value to maintain the bike's geometry (usually about 30-35mm rear for 40mm front).
With the shock, the ideal is the get the target sag while still having 6-8mm of free sag. If you have to use a lot of preload to get the target rider sag, you may end up with no free sag and the rear suspension will not work well at full extension. In this situation, you should have the rear spring replaced with a stiffer spring. In the free sag is correct and you cannot get enough sag, you may need a softer rear spring.
The general target for street is ~1/3 of total travel.
Rebound is set after sag because preload will affect rising rate (rebound). Compression is set for plushness vs chassis pitch control.
