Originally Posted by markjenn
If you want to use the minimum weight, balance the wheel without the tire and mark the heaviest spot. Put this next to the tire dot rather than the valve stem.
Spot on. Even on a big old 205/55, you may find you need as little as 1/4 oz. (7 grams) to balance it.
Use a Sharpie or similar permanent marker to mark the inside of the wheel and you'll have a permanent reference point. For even more accuracy when balancing the wheel without the tire, ensure the valve core and valve cap are installed.
