Triple thank you for you reply, that thread has been extremely useful. I've done a lot of searches looking for answers and opinions but I really didn't expect tires from the same manufacturer to feel so completely different especially since the Pures and the 2Cts have very similar profiles. I really felt like the tires were put on improperly but after careful inspection they were good and after a few miles they felt fine.
Originally Posted by Sal_R1
This is a suspension issue. The power pures have a taller profile (especially the rear tire) & changed the geometry of the bike enough for you to feel it! Cornering should be the same but as you didn't feel comfortable on them i doubt you tried aggressive lean angles.
They felt better after a few 100 miles because you had worn the rear tire down (l owering ride height) thereby compensating for adjustment!
If your suspension is dialed in then you would only need to make minor front & or rear ride height adjustments to compensate for different tire profiles.....
Sal, that is exactly what I was wondering, thank you. Just seems odd to me that the Pures and 2cts would feel so different.
Thanks again guys for the great info!!!
