Flipped the eccentric shock mount - wow! - BMW S1000RR Forums: BMW Sportbike Forum
Old 05-16-2011, 10:18 AM   #1 (permalink)
Default Flipped the eccentric shock mount - wow!
This made more of a change than I was expecting. The bike is imminently flickable now without any stability issues. Enters, holds, and finishes turns much better. Very happy.
Old 05-16-2011, 06:55 PM   #2 (permalink)
Nismo400rgtr's Avatar
What exactly does it do to geometry that makes it so advantageous?
The Old- 94 Suzuki RF600R
The New- 2011 TG S1KRR
Old 05-16-2011, 08:05 PM   #3 (permalink)
Pappy's Avatar
Did you change your front heighth at all?
______________________________
Scott
Pappy is offline   Reply With Quote
Old 05-16-2011, 09:14 PM   #4 (permalink)
I did not.
Old 05-16-2011, 09:16 PM   #5 (permalink)
Ride height: Consider your bike as just a frame and subframe hanging in space. Ride height is a measure of how high the steering head (front) and subframe (rear) are above the ground, and juggling front and rear ride heights will change your bike's geometry. Tipping the bike forward with less front ride height will reduce rake and, more importantly, trail. This will quicken your bike's steering, but reduce stability.
Read more: Suspension Setup Guide - Sport Rider Magazine
Old 05-16-2011, 11:27 PM   #6 (permalink)
CQBRR's Avatar
WTF is "eccentric" shock mount? pics plz...
Yes that is a BMW and yes I am glad to see you
CQBRR is offline   Reply With Quote
Old 05-16-2011, 11:32 PM   #7 (permalink)
It's the top mount where your shock attaches. You can loosen/remove the bolt, take out the insert and flip it... put the bolt back in tighten down the shock and you have just increased your rear ride height.
Old 05-17-2011, 04:31 AM   #8 (permalink)
Copied from Google Dictionary:
Ec·cen·tric Adjective /ikˈsentrik/
(of a thing) Not placed centrally or not having its axis or other part placed centrally
(of a circle) Not centered on the same point as another
(of an orbit) Not circular
Fungus Amongus is offline   Reply With Quote
Old 05-17-2011, 06:36 AM   #9 (permalink)
beemersean's Avatar
How easily does the eccentric adjuster come out once you've removed the bolt?
Do you have to take weight off the shock by lifting the bike first?
Step by step instructions would be great as I want to try this mod
Cheers
beemersean is offline   Reply With Quote
Old 05-17-2011, 07:46 AM   #10 (permalink)
The swingarm needs to be unweighted. I used a 3/8" (I think) steel rod from Home Depot & slid it though the swingarm pivot point & secured it with jack stands. With the bike on its rear stand, I lowered it onto the stands. Undo the bolt (helps to have someone lift up on the wheel to slide out the shock bolt. Reverse the eccentric cam position, reinsert bolt and voila. Whole thing took ~15 mins.
