What you are describing is a geometry problem, not a suspension problem.
All 848's, 1098's, and 1198's have this same problem.
Like the S1000RR the Ducati's need a different offset triple clamp.
We go from 36 mm stock clamp to a 30 MM clamp.
This adds 6 MM of trail.
Trail is one of the main factors that allows you to "Finish the Turn"
More Trail gained by changing the triple clamps will make the bike turn in faster, do transitions faster, make the bike more stable at speed, and allow you to Finish the turn or hold your line.
The part about holding your line, what is important here is to know that means without have to work hard to do it.
The bike should be neutral, not pushing to the outside or falling to the inside.
