04-24-2011, 11:09 AM
Sachs rear shock internals adjustment ?
Hi,
I have found a great set up for me on my S1000RR: for road use only, and my weight at 70kg (154 lbs).
Adjusted rear ride height (eccentic washer), and front & rear preload to get ideal sag, etc. Dampings of front & rear, compression & rebound works great on standard settings.
The ONLY issue is that the rear High Speed Compression damping even at the lowest setting of 1 is still too hard.
Is it possible for a service center to adjust the Sachs rear shock internals so as to ONLY reduce the High Speed compression. And who can do this preferably either in Belgium, Netherland or Germany? Thanks. CTD
04-28-2011, 10:41 AM
Originally Posted by poiteau
Hi,
Good to have a reply
I only do very occasional track days and they are all in Spain where I have a Yamaha R1 2009. Will follow up your information. Thanks.CTD
05-02-2011, 08:19 AM
Hi CTD,
.........Interesting statements,, I am much the same wieght 73Kg usually!,,
I have raised rear ride hieght adjuster and set sag acording to BMW handbook, using those numbers rear 20mm front 14mm ( from memory),, I found I had to wind back the rear shock a lot to get to those figures and the front forks show two rings..
I have played around with damping compression rebound and I too think I have a good set up for roads and a pretty good one for track too, The rear is a little firm but not hard so I was wondering what your numbers are for your set up ?? really stock with rear rebound on 1 ?
R1200GS
_______  _
2010 Blade
2006 Blade
GS650BMW
2003 Blade
2002 RSV Mille
2002 GSX1000
2001 Blade
05-02-2011, 11:37 AM
Hi bellyboyrr and CTD,
Do you mind sharing your front and rear suspension settings for preload, rebound and compression?
// 2008 X5 Black
05-02-2011, 02:25 PM
Hello,
I will send you my full setup as soon as I will be at home.
I use my S1000RR only on track and my wheight is 80 kg.
05-03-2011, 07:34 AM
Hi Shasshankmittel .........thats a name!,,?
my 90% road 10% track settings are for UK roads...which means bumpy!
fast A roads Bumpy B roads.. not sure how it is in east coast but my stint riding in L.A last year I reckon these should be ok too,
Important to have sag set correctly before doing any of the following..
Sag as I said earlier is easy using the handbook guidelines..Ive tried it and compared it to using a full race technique set up guide and works fine for most riding on the roads..
My Sag (as per book ) 20mm rear 14mm front, (tip for ease of doing the front use a cable tie)
I have flipped the eccentric ride hieght adjuster to gain the 10 mm to increase turn in rate, there is little lost in stability
Rear shock Lowest screw Rebound is set to 4 (Std is 5)
Top screw Low speed compression is set to 5 (std is 4)
Top Nut high speed compression is set to 5 (std is 6 )
Forks two rings showing on my sag setting if that helps?
top screw Rebound is set to 4
bottoom screw compression is set to 5.
this gives me a reasonably comfy ride and although the rear is firm it does not fling you out of the seat unless you hit a really good bump!
if you find it still is to harsh at the back lower the rebound to 4 or even 3, this will make the back end move around a little but will be,,comfortable.
tyre presures on my Conti SPort attacks, 35 front 39 rear although I am not happy with these tyres they work ok under normal use..
R1200GS
_______  _
2010 Blade
2006 Blade
GS650BMW
2003 Blade
2002 RSV Mille
2002 GSX1000
2001 Blade
05-03-2011, 09:54 AM
Thanks bellyboyrr, I'll try your settings. The roads here on the east coast are not good and probably your settings might work for me too. Yes..that my name...Shashank Mittal.
// 2008 X5 Black
