Flipped the eccentric washer - BMW S1000RR Forums: BMW Sportbike Forum
Old 04-03-2011, 07:50 PM   #1 (permalink)
chopt's Avatar
Default Flipped the eccentric washer
I tallied over 11k miles without making this adjustment. The ride height was the main reason why I selecetd this bike over the others. So, initially I didn't want'a raise it none. At my weight setting my SAG #'s and dialing in the front and rear compression and rebound damper's. I settled in on how it handled and got used to the input's it required to get it to rail the twisties. Being this bike serves street duty only, the only suspension mod I was considering is straight rate springs.
Fast forward to yesterday, I flipped the wahser's and with D's advice I dropped the tubes giving me 8mm's above the upper triple clamp. When I left the driveway I noticed the difference instantly. It felt more agile, the slightest input to the bars resulted in an effortless turn in. I then got to put 120+miles on it thru some of the twistier roads around my area. It was a noticeable positive difference. Although it raised the RH slighly, the benefits out way that minor personal set-back. Only making this adjustment, single rate springs maybe the only mod I'll make. Unless I run across a deal on fork valves that I just can't pass up.
Old 04-03-2011, 09:52 PM   #2 (permalink)
I was told to flip the rear suspension washer, and have the top of the front suspension level with the top of the triple tree, by a suspension guru in California!
Who is your advice coming from?
I am trying to get the best balance out of the stock suspension!
Old 04-03-2011, 09:57 PM   #3 (permalink)
I put that info in another thread for Chopt... The info was provided to me through some AMA racing guys running superstock or the like. I was originally running the front close to flush and then took the advice and dropped the front... I only needed to drop 4mm in the front, but it was immediately noticeable. Prior to that I was running with the rear insert flipped and the forks almost flush.
Old 04-03-2011, 10:03 PM   #4 (permalink)
AMPforE's Avatar
What are your suspension settings? And how much did you seat height increase, I don't have an issue but would like to know. I may flip the washer to see if I get the same effect.
My settings are:
Sag:
Front 39
Rear 30
Front
Rebound 10
Compression 5
Rear
Rebound 8
Compression Low 6
Compression High 5
1991 Suzuki Bandit 400
1996 Kawasaki ZX6
2006 Triumph Speed Triple
2009 Honda CBR1000RR ABS
2010 BMW S1000RR
ABS-DTC-Shift Assist
Fastest Color Motorsport
Old 04-04-2011, 02:09 AM   #5 (permalink)
S1RR's Avatar
My settings are:
Sag:
Front 39
Rear 30
Front
Rebound 10
Compression 5
Rear
Rebound 8
Compression Low 6
Compression High 5
But the important question is, How heavy are you?
A 150lb rider will need completely different settings to 250lb rider.
Garage:
S1RR is offline   Reply With Quote
Old 04-04-2011, 02:35 AM   #6 (permalink)
AMRRA12's Avatar
Settings (other then sag) for the most part have very little to do with weight and more to do with how you ride I.e.riding Style ,skill, surface and so on it's a very bad idea to post or even run someone elses setting unless you ride exactly like them and have the same skill level. there are no magic numbers
AMRRA Open SS Expert #1
Sponsors:
Lithia Motors
Snap-on tools
Big Bobs Flooring
Mat-Su Tattoo
Old 04-04-2011, 03:08 AM   #7 (permalink)
DrIoannis's Avatar
I did flip the rear eccentric some months ago with stock front.On my weight (98kgr with gear) the front just collapsed on breaks and at the same time I was loosing my rear.I returned to stock and just lowered my front 1 line.The bike became a bit more agile without the previews problems.Now with the Ohlins TTX (2-3mm higher) and the 1 line lower front (revalved,springs for my weigh) the bike fells really nice and agile.
Old 04-04-2011, 06:01 PM   #8 (permalink)
chopt's Avatar
Raising the rear(flipping the washer) requires you to raise the front also. Not raising the front when you flipped the washer reduced the rake causing a quicker turn-in. The tucked feeling you felt causing the rear to get squirrely. For ****'s and giggles flip the washer again and raise the forks 8mm. That is 8mm from the top of the tube cap to the upper clamp.
My seat height did increase. But the performance gain made that null and void. To be exact, I'd say it lifted it half an inch to an inch.
Old 04-04-2011, 11:24 PM   #9 (permalink)
Why exactly would you want to raise both the front & rear of the bike?
Assuming they are raised equally, all you are doing then is raising the CoG.
Old 04-05-2011, 07:55 AM   #10 (permalink)
awelch85's Avatar
Any chance someone can do a pictorial walk through of flipping the washer?
