240lb with gear, what suspension do i need? - BMW S1000RR Forums: BMW Sportbike Forum
Old 02-21-2011, 09:11 PM   #1 (permalink)
Default 240lb with gear, what suspension do i need?
hey guys, i will be purchasing an s1k shortly... title says it all.
im 6'3 220lb. (fig. about 20 more lb. for leathers, etc?)
before all of the fat jokes come in, im a work out buff etc,,, muscular build..
anyway, what do i need to do to the bike suspension "right' ?
im assuming minimum: spring kit for the forks?
and probably a new shock for the rear? if i can remember i want to say that most stock rear shocks arent meant to handle that weight, or even with a fat man spring its basically at the limit of its design instead of being in the middle with adjustments etc...
thanks for the help, any links suggestions are greatly apprecitated.
c.rod is offline   Reply With Quote
Old 02-21-2011, 09:40 PM   #2 (permalink)
BUZZ's Avatar
25-30MM FORK KIT ,OHLINS TTX/k-tech 35dds rear shock with spring to match you weight...about 2k to purchase plus fitting...
Old 02-21-2011, 09:46 PM   #3 (permalink)
i started looking around on kyles website.. so if you want the rt forks also your looking at $4k.. wonder if theirs any price break if you buy both.....
Old 02-22-2011, 01:03 PM   #4 (permalink)
BUZZ's Avatar
Thumbs down
internal fork kit here in the uk are roughly £980,in the uk ohlins uk will fit them free aswell.dont know what they cost in the states but i cant see them costing much more..???
