01-25-2012, 02:23 PM
Help good addvice need racers opinion
01-25-2012, 02:24 PM
Personally I don't think it is a good idea (at all) to run slicks on the street. Contrary to belief that it would provide superior traction, it actually doesn't due to the simple issue with maintaining enough heat in the tire to allow it to warm up to proper operating temperature (and stay there). Even if you were riding twisty mountain roads, it just won't put enough heat in the tire (and keep it there) like it was designed for compared to if you were on the track.
That's my $.02
01-25-2012, 02:43 PM
take note on what the experienced rider aboive as to say, and dont do anything stupid down there.
be safe!
01-25-2012, 02:51 PM
The Factory Knows Best...
Slicks will also suffer from heat cycling issues after 6 or so warm ups.
Triple
2010 BMW S1000RR
2009 Aprilia Dorsoduro
2006 BMW R1200RT
01-25-2012, 02:52 PM
Triple
Come on T.... a backpack w/some tire warmers, extension cord and just make sure you stop where there's power
01-27-2012, 04:07 AM
01-27-2012, 10:14 AM
Hey Chris... don't know exact pressures for those particular race tires, but would certainly say they seem too high based on my experience with other slicks. Even the harder carcass slicks out there don't take that much pressure when cold. And since your rear is going to heat up more, the rear always has less pressure than the front.
My suggestion would be to do a Google on those particular race slicks, check out some forums, maybe stop in over at the WERA forum... I'm sure they'll have pretty good advice. However, what pressures they provide as cold, you might want to bump it a couple pounds from that since you won't be putting as much heat in the tire as a person on the track would. The important thing is going to be the hot pressures... so take a gauge with you and check them while you're out.
Good luck.
01-27-2012, 11:22 AM
Good luck.
thanks what u usally put in them front and rear say 32 front and 29 rear im not sure
01-27-2012, 11:29 AM
Totally depends on the tire, not familiar w/those... but to give you some examples.
What I used:
Michelin race DOTs - 22/28 (r/f) --> hot pressure 31-32 front, 27-28 rear
Michelin Slicks - 28/29 (r/f) --> hot pressure 32.5 on front, 32 on rear
01-27-2012, 10:30 PM
What I used:
Thanks for those. I play around with it a few psi more. dew to heat ok cheers
