Not all tyres are equal.
You need to find out the measurements of the tyre from Metzeler.
For example a U.S made Dunlop d211gpa 190/60 is 191.3w x 657.4 diameter but the U.K made kr108 195/65 is only 191w x 656 diameter.
I am currently running Dunlop front 125/80 which is only 1mm taller but 5mm narrower than a q2 120/70.
I use dunlop wets and the rear 190/55 is 7mm taller and 9mm narrower than q2 190/55
Hope all this made sense. So check the actual sizing, as maybe the pirelli or metzeler wet 190/60 is similar to the Tyres you are already using.
