Will 2009-2011 wheels fit a 2012? - BMW S1000RR Forums: BMW Sportbike Forum
 1Likes
post #1 of 22 (permalink) Old 11-02-2012, 12:11 PM Thread Starter
I want to pick up a spare set of wheels for my track rubber, just want to make sure older wheels will fit without issue.
Reject is offline
post #2 of 22 (permalink) Old 11-02-2012, 04:07 PM
No problem-they are the same.
gixerconvert is offline
post #3 of 22 (permalink) Old 11-24-2012, 07:38 PM
AMPforE's Avatar
Not so fast, yes they are the same wheels but the wheel was moved a millimeter or two to the right. So you will most likely need to use your spacers from the old wheels. I know because when I fitted a set of Carrozeria's the spacers were off and the rear rotor grinded up rear caliper a little. That's when I found out about the wheel being moved.
1991 Suzuki Bandit 400
1996 Kawasaki ZX6
2006 Triumph Speed Triple
2009 Honda CBR1000RR ABS
2010 BMW S1000RR
ABS-DTC-Shift Assist
Fastest Color Motorsport
AMPforE is offline
post #4 of 22 (permalink) Old 11-25-2012, 05:45 AM
Why,on earth would BMW want to move the wheel off-centre?
There is only one place for a wheel-and that's in the middle!
If you had a problem with aftermarket wheels,I would suggest the problem was not caused by BMW!
OE wheels fit straight in.I haven't measured the spacers but they look the same and the wheels fit straight in,with no problem.
post #5 of 22 (permalink) Old 11-25-2012, 09:46 AM
QuikSanD's Avatar
some bikes come with wheels off center to achieve a desired handling characteristic... I can't speak to what affects what but I know I've read about it in a few different books.
2013 s1k, Austin Racing GP3, PC V, fries and a drink
QuikSanD is offline
post #6 of 22 (permalink) Old 11-25-2012, 01:14 PM
DBX
DBX's Avatar
Ive got 12 wheels on my 11 atm. (well I think they are since theyre the black ones).all is fine
DBX is offline
post #7 of 22 (permalink) Old 11-25-2012, 01:25 PM
AMPforE's Avatar
@DBX, if you used your original spacers it would not make a difference.
@gixerconvert, that the way it is. Like it or not, stupid or not, BMW moved the wheel. The aftermarket wheels came with new spacers and the rear was not where it used to be. I was not the first to have this issue. When you call the any aftermarket company that uses different size bearings and different spacers they will ask you what year do you have. I told them 2010
To further complicate things I light crank 2010, an that's the spacers they gave me, only to find out I needed the spacers for a 2011-12.
I lost two track days and $500 over this issue, I know what I am talking about. If you buy OEM wheels, use your current spacers, if you but aftermarket wheels with new spacers pay attention to the rear rotors alignment inside the caliper.
1996 Kawasaki ZX6
2010 BMW S1000RR
AMPforE is offline
post #8 of 22 (permalink) Old 11-25-2012, 06:14 PM
Actually,you do not know what you are talking about!
There is absolutely NO DIFFERENCE between OEM '10/11 wheels and '12 wheels.Also the spacers are exactly the same.
If you had a problem with your Carrozeria wheels then I suggest they were the problem-not BMW altering their motorcycle.
Just for the record,sometime this week I will fit '10 PVM and '10 BST wheels to a 2012 bike.(I don't need to fit the front because I know they will fit)My betting is they will go straight in-and if they don't I will be the first to admit I was wrong.
post #9 of 22 (permalink) Old 07-12-2013, 12:19 AM
TYoung's Avatar
I would like to update this post. I have a 2011 (Bent rear Rim), and just got a 2012 rear rim. Tried putting on with original 2011 spacers and it would not fit. The rotor would not slide up into the pads.
Had to put the 2012 spacer on, and now everything looks and rides fine. I attached a pic of the two spacers. The one on the right (or top) is the 2012 (smaller).
TYoung is offline
post #10 of 22 (permalink) Old 07-12-2013, 01:21 AM
meldog21's Avatar
Thank you, thank you, thank you. I have been on this forum for months hoping to actually learn some kind of valuable information about the S1000. Finally, someone posted information with a picture that shows something I might need to know (if I was in the market for spare or new wheels).
Its sooooo refreshing to get some actual facts rather than post after post of opinion with no factual back up.
Dog
meldog21 is offline
Human Verification
