What is required for install? - BMW S1000RR Forums: BMW Sportbike Forum
post #1 of 8 (permalink) Old 12-11-2012, 03:46 PM Thread Starter
CYD
I am looking to add the reverse shift and the data logger to an S1000RR/HP4 with a quick shifter.
Is there any remapping of the ECU or anything beyond simply bolt-on of the reverse shifter and pluggin in the data logger?
Has anyone installed these on an S1000RR?
Thanks,
~CYD
CYD is offline
post #2 of 8 (permalink) Old 12-11-2012, 05:06 PM
Stealth's Avatar
I have the HP reverse shifter. It was dealer installed but I was there when it was done. It's a bolt on job with a slight cut of the belly pan (didn't need removed to do the cut).
Stealth is offline
post #3 of 8 (permalink) Old 12-11-2012, 05:39 PM Thread Starter
CYD
With a quickshifter, does that affect whether there is any electronic mapping changes necessary?
CYD is offline
post #4 of 8 (permalink) Old 12-12-2012, 04:51 AM
Stealth's Avatar
If you have the HP4 then it already has quickshift. Inverting it to give you race style pattern is a purely mechanical procedure as far as I know.
Stealth is offline
post #5 of 8 (permalink) Old 12-12-2012, 01:48 PM Thread Starter
CYD
The dealer I am looking into is saying that it will be 2 hours of labor to install the reverse shift, because it requires a computer update to work with the Reverse shift and the quick shifter. They also say installation of a data logger requires computer update.
So I want to figure out whether those are legit expenses for installing the reverse shift on an HP4.
CYD is offline
post #6 of 8 (permalink) Old 12-13-2012, 05:25 AM
Stealth's Avatar
Can't speak for the data logger but my dealer fitted the reverse shifter for free.
Note here I've spotted some "HP" parts that are "more" HP than the usual HP parts. Eg there's a set of BMW "HP" levers where the brake has a remote adjuster etc in addition to the usual HP levers. So maybe you're being quoted for a different "HP" shift inverter.
Stealth is offline
post #7 of 8 (permalink) Old 12-14-2012, 12:13 AM
DMesher's Avatar
BMW Data Logger
I purchased the BMW 2D data logger after rejecting the thought of spending $650 for the IR transmitter/receiver pair for my bike. It will be the best money you spend if you race. It is plug and play (plugs directly into the CANBUS connector under the passenger seat without modification) and VELCROS into the left or right cutout on the tail section. Logs 33 parameters at 100Hz fully GPS referenced as soon as the bike is started. Engine start stop cycles start new files. Download is automatic to a USB flash drive as soon as it is lugged into the unit mounted to the bike (about 3in L x 1.5in W x 1in tall) The analysis software is comprehensive, uses Google maps satellite images to overlay the data onto and allows the automatic segmentation of laps based on selection of the start/end point for the track. Capable of lap by lap analysis (times, shift points, brake points, lean angles, wheel slip, throttle position, ecu throttle, position DTC output etc. etc.
I have attached a screen shot of one of my race lap sessions.
Darel
I looked at the thumbnail attached below and it has been so compressed that it is almost unreadable. If someone is interested in some screenshots or information just pm me and I will email some to you.
DMesher is offline
post #8 of 8 (permalink) Old 12-17-2012, 01:22 AM
Bullet's Avatar
I didn't install the Gilles HP Rearsets, which i hear do take 2 hours to install.
I installed the Attack Performance Rearsets with GP shift. Install took 30 minutes total. And I do mean total. No problems with the data log or software. Verified at my dealer took 5 minutes for him to plug in and verify everything.
Let them know you're price shopping.
Hope this helps. Good luck.
2014 BMW HP4/C - #5096
2008 Ducati Desmosedici Team Colors - #187
2015 One Bad Ass Schwinn on layaway.
"Endeavor to do something for someone who cannot repay you".
"Each day, you wake up and decide who you wish to be. Endeavor to do something great".
Bullet is offline
Human Verification
