DTC and drag racing? - Page 2 - BMW S1000RR Forums: BMW Sportbike Forum
Old 12-12-2012, 05:19 PM   #11 (permalink)
good job! thats a very respectable number for first track outing with the bike.
if you gear it down it'll be a lot easier to launch.
2011 S1000RR 8.93@162mph
russianvr4 is online now   Reply With Quote
Old 12-18-2012, 10:51 AM   #12 (permalink)
Originally Posted by spunant View Post
So my time doesn't start when the green light comes on?.. so is it when I break the beam?... and the 60' is that the first 60 ft?..I'm guessing thats where you make up or lose the most time?
yes your time start to count when you start to move, not when the green ligth shows
ohh and if you are going to make a burn out, dis engage the abs too...becuase the abs also push your rear brake when enabled
evildrag is offline   Reply With Quote
Old 05-21-2013, 10:43 PM   #13 (permalink)
I hadn't dragged raced in 6 years... Ran my 2010 S1000 at 10.55 @ 141mph on 5th pass. Only 1.9 60ft, and I'm 215 Ibs. Get my 60 down in low 1.? I should run 9s
Sent from Motorcycle.com Free App
Cory's1000rr2010 is offline   Reply With Quote
Old 05-22-2013, 06:29 AM   #14 (permalink)
1000RR Bahrain's Avatar
I got nearly the same on my first drag night, around 10.5 with traction on but got much higher trap speed due to my bike's mods and my weight of 180. Is your bike stock? Did you run with traction on?
You could run in the 9s but you may need a front strap kit at least to help you put the power down much earlier and harder.
2010 S1000RR- Austin Racing ARCS Exhaust - Bazzaz ZFi - MWR Air Filter - BST wheels - Fabbri screen, 5" stretch, lowered, Brock's Performance clutch mod & heavy spring kit & front strap kit, APE Clutch, -1 front sprocket
8.87 sec @ 158.3 on pump gas & Conti SportAttack2 tire 190/55
My YouTube channel:http://www.youtube.com/user/BMWS1000.../videos?view=0
