Originally Posted by Taino Warrior
Need any advice or info bike ran fine two days ago . Went this afternoon to start it cranks no problem just wont turn over got plenty of fuel just wont start any help would be appreciated 2012 1000rr miles 1098 only.
Your description is confusing. You say it "cranks no problem" but then you say it "won't turn over". These are generally meant to be the same thing. If it cranks over then the motor is turning over.
From what I am interpreting the bike powers up fine but won't turn over/crank. Probably a battery issue. Check connections to the battery. Put a trickle charger on it overnight. Try it the next day. Just because a battery can power up the instrument panel doesn't mean it is strong enough to turn over the engine. A battery load tester would be of great use in this circumstance.
