Strange issue - Page 2 - BMW S1000RR Forums: BMW Sportbike Forum
Old 12-10-2012, 05:26 AM   #11 (permalink)
Originally Posted by Dazzle View Post
Right hand switch block mate. Known problem and your dealer is taking the micky, mine fessed up right off the bat and replaced same under warranty.
Forgot to touch base about this issue.
Took the bike out for the day, it was pretty more down my way.
Stopped off at the local petrol station to fill up. Went to restart bike, no response. Wouldnt start.
Had to wait around for a few hrs for my roadside assist, eventually they came and the bike has been at the shop for about a week and a half.
BMW have told me that its the starter switch causing the issue, got to wait a few more days for the parts to arrive from Germany.
But im skeptical that this solves my original issue.
The first time i had problems, the bike cut out while i was riding it, at speed, on a racetrack. Why would a faulty starter siwtch cause my original issue?
The more recent occurence, it occurred on a hot day here in Melbourne, so im starting to think this is a heat related issue.
I have been told that a number of S1000s have been brought in with a similiar issue I'm having.
Anyone else having the same issue?
Deano is offline   Reply With Quote
Old 12-10-2012, 08:04 AM   #12 (permalink)
Hi Deano, I had this prob on the left hand S/W block, heat causes it, I had broken the warranty seals on the switches when installing some heli bars (didn't really understand how they came off, weird mounting sys).
So I pulled them apart, the switches are Ok, the wiring is printed on the plastic with a gold ink. The problem I found is were the gold traces join to the pins in the loom connector block. I think that when it heats up enough ( most likely radiant from the engine) the junction/join between the metal pins and the gold trace breaks. When it cools down all is good. This is all covered by an epoxy weatherproof coating which doesn't stick very well, so you get it off with a hobby knife reasonably easy. Solder wicks along the gold traces well and 5 min epoxy will weatherproof it.
I ended up soldering every trace, it takes a while to do and you need to be careful, but if your warranty's ended and you want a proper fix this works. My right hnd block hasn't broken yet but if it does I'll do a diy with photos. )
Reaper is offline   Reply With Quote
