does anybody knows which levers will fit the 2015 there seems to be little to no info on this, I have short fingers and the clutch is a pain because the engagement point is so far.
I've got the HP Lightech levers and they work great. I wouldn't have gotten them had I not had the $1,000 credit when I bought my bike though because it was $550 for the levers alone.
I got a set of cheap ones from eBay. The brake side fit well, the fit on the clutch side was a little sloppy and didn't consistently trigger the clutch pressure switches. With some thread tape and heat shrink tubing, I was able to modify a couple of non visible areas and get them working 99% of the time. The biggest issue was if the bottom switch doesn't engage when the clutch is released, the quick shifter and cruise won't work.
I bought a set of ebay ones and they work great. If yoiu have a red bike though the red is more of a pink on the eBay levers. Black or grey is the way to go. I can post a link if you have any interest.
Here is the link, I bought these. The red was very pink. Contacted seller and he sent me black replacement parts free of charge. Once i got clutch cable adjusted right it was golden
Link is being weird. I'll try again tom from my laptop. Sellers's name is divinitymotor.
Lightech KLEV042J(this is the correct one even though the catalogue says different)
The catalogue code clutch side is too short for the micro switch so this is the code for the 2014 S1000R and it's the correct one.
Work well, micro adjustments and good value for money.
Would be nice if Brembo would hurry up and update their clutch lever for 2015.
