Installing Ohlins Forks, Removing Stock Forks, Frt Wheel, and Setting SAG, all in one - Page 2 - BMW S1000RR Forums: BMW Sportbike Forum
Old 11-29-2012, 07:38 PM   #11 (permalink)
RIQUE's Avatar
Default IMPORTANT NOTICE
ITS IMPORTANT TO NOTE THAT THE UNITS LISTED IN THIS PROCEDURE SHOULD READ N/m and not N/mm. Make sure you get this right or maybe the original poster should correct.
Life Rewards Action.
He who is not afraid is safe!
You get used to speed fast!
Panic is NOT a strategy!
RIQUE is online now   Reply With Quote
Old 05-12-2013, 11:27 AM   #12 (permalink)
RIQUE's Avatar
Hey Folks, This weekend I re installed my front shocks. I decided to fine tune the position and after talking to Dan Kyle, reading on the net, cross referencing pictures etc. I have come to the conclusion that the correct fork position for the FGRT 202 is the one that aligns the fork flute edge to the bottom of the lower triple. 5mm should protrude beyond the beveled angle on the top of the fork head. My pictures and some from the net. Hope this helps others reduce their labor time. Riq
Installing Ohlins Forks, Removing Stock Forks, Frt Wheel, and Setting SAG, all in one-dsc_0028.jpg   Installing Ohlins Forks, Removing Stock Forks, Frt Wheel, and Setting SAG, all in one-bmwfork.jpg
Old 05-12-2013, 11:39 AM   #13 (permalink)
Great post Rique, having a good starting point will definitely save time. But for those reading and you as well. Keep in mind, this is a geometry setup that will be good for some and not as good for others. And depending on the application (what track, conditions, etc.) is just that - a starting point. Geometry fine tuning is VERY much a personal preference although there are certainly some things that most everyone would agree - just don't work well!
Suspension is a never ending mission. You're always chasing something. I'm definitely learning that a lot these days trying to chase tenths. The trick is to know just what to change
__________________________
Old 05-12-2013, 12:12 PM   #14 (permalink)
RIQUE's Avatar
Smile
I certainly agree that you need to fine tune to your rideing application and style. However, my point is that if you start with the top regulators flush as can be seen on the right side fork the setup is incorrect and bike will not turn as also reported by other users on this forum.
Old 05-12-2013, 12:56 PM   #15 (permalink)
True (for some, maybe many). But there are some riders that don't mind that little battle to obtain more stability (which is the trade-off). For example, Taylor Knapp is known for preferring a front end high because that battle we're talking about doesn't affect him as much - he's a tall lanky guy that can use that leverage to tip it in all day. The other thing noteworth of mentioning is tires and their impact (height/width). Which can result in further changes to geometry.
Bottom line is to start w/a known geometry for a particular tire and then your life has been made easier. That said, maybe I missed it, what rear ride height did Dan Kyle recommend for the front end geometry you've gone with?
Old 05-12-2013, 01:32 PM   #16 (permalink)
Site Sponsor
HardRacing's Avatar
... 5mm should protrude beyond the beveled angle on the top of the fork head. My pictures and some from the net. Hope this helps others reduce their labor time. Riq
LOL.. Hey that's our bike in the 2nd Pic.
We came to same conclusion you did when we installed the Forks back a couple years ago... before that Sport Rider Photo Shoot.
HardRacing.com - 704-799-2192
>> S1000RR PROJECT BIKE BUILD <<
OHLINS Premier Dealer_
Great Prices, Fast WORLD WIDE Shipping, Large Inventory and Excellent Customer service.
Follow us on TWITTER & Facebook to get Exclusive SMOKIN' Deals
Celebrating our 14th year in business.
HardRacing is online now   Reply With Quote
Old 05-12-2013, 06:27 PM   #17 (permalink)
RIQUE's Avatar
He suggested I flip the rear shock top bolt holder. That gives you around 2cm extention in the rear...not really sure I should do that though..,
Old 05-12-2013, 06:30 PM   #18 (permalink)
RIQUE's Avatar
LOL...I just figured that out. It is your awsome bike. Have you tried rotating the rear top mount bolt for the shock thingy?
Old 05-12-2013, 07:03 PM   #19 (permalink)
Site Sponsor
HardRacing's Avatar
It is a setup that BMW specifically designed as an Option.
But, we never go around to trying it.
Old 05-12-2013, 08:41 PM   #20 (permalink)
My guess is it gives you 2X that, right?! So 4mm... I imagine it's a 2mm offset so flipping it would give you two times that.
If Dan said to do it, I'd go with his advice. He knows his suspension stuff! It will tip in better too.
