Adjusting the spring preload - Page 2 - BMW S1000RR Forums: BMW Sportbike Forum
Graves MotorsportsSportbikeTrackGear
Old 12-10-2012, 06:52 PM   #11 (permalink)
Taylor's Avatar
No.
On the hp4 there is only 2 spots to manually adjust anything. Both are preload and you turn the back with a 13mm wrench, it's backed out completely and it still only has 3/4 inch sag. If I tighten it it's worse, goes to .5 inch then .25 inch, I eventually stopped and returned it to stock setting on the back.
The front is turned all the way out and we still don't have enough sag, it's about 3/4 inch to.
Going to do some research on the web.
2010 Mineral Silver S1KRR
2012 Motosports. S1KRR
2013 HP4 Competition #0373
Taylor is online now   Reply With Quote
Old 12-11-2012, 05:58 PM   #12 (permalink)
Stang10189's Avatar
The bike MUST be running and warm
Old 12-11-2012, 06:37 PM   #13 (permalink)
Taylor's Avatar
Bike running, temp was 190
Any other suggestion
Old 12-11-2012, 09:24 PM   #14 (permalink)
I can't comment on the front issue. As for the rear, my bike came from the dealer with the chain too tight. This didnt allow the swing arm much travel. I couldn't set the sag until I adjusted the chain properly.
tlrdynes is offline   Reply With Quote
Old 12-13-2012, 09:02 PM   #15 (permalink)
Originally Posted by Taylor View Post
Both
Im 250lbs
Let me know if you figure out a setting that works for you. I weigh about the same with gear on. I get my bike next week and from the looks of the manual it seems a little confusion when it comes to the electronic part.
Joshua1796 is offline   Reply With Quote
Old 12-13-2012, 11:05 PM   #16 (permalink)
Originally Posted by 1000RR View Post
Something definitely doesn't sound right... So in the rear, you're backing out the larger collar on the top of the spring?
Sorry... I was thinking normal suspension... forgot you had that electronic assisted stuff. I'm no help there, never messed w/that stuff.
__________________________
