Installing a hardwired power outlet and GPS mount - Page 5 - BMW S1000RR Forums: BMW Sportbike Forum
Go Back   BMW S1000RR Forums: BMW Sportbike Forum > General BMW S1000RR Discussions > S1000RR/HP4 Do-It-Yourself
Graves Motorsports
Old 10-20-2012, 02:43 PM   #41 (permalink)
shashankmittal's Avatar
Originally Posted by FrankoQ View Post
Anyone?
I dont have the pics, but you can easily remove the left side body panel and hide the wire behind it all the way to the front. Left is better since most heated gear has connectors on left.
2013 BMW F800GS
2010 S1000RR (track only) (street parts available for sale)
2004 Royal Enfield 500 Electra
1997 Yamaha RX135
1990 Yamaha RD350
Old 10-20-2012, 03:01 PM   #42 (permalink)
FrankoQ's Avatar
Thank you for the response.
2012 BMW S1000RR - Motorsport
2006 Honda Interceptor 800
1996 Honda VFR 750
FrankoQ is offline   Reply With Quote
Old 10-21-2012, 11:07 AM   #43 (permalink)
Originally Posted by Mack View Post
Here is where the BMW dealer installed mine.
Reasons he gave was: "It cleared anything I might plug into it from getting hit the handlebars" and "That plastic piece is the cheapest thing on the BMW (maybe $12 ?)."
Mack
Today I installed a Powerlet outlet in the same location -- easy! I bought the Powerlet PKT-042-48 kit. There was about 6" or so slack, but the 36" kit would have been too short. I also bought the short outlet, since I wasn't certain about how much clearance I had behind the panel; fits fine. The one excess part I bought was a right angle rubber boot. My plan was to install the outlet in another location which required the right angle. After tinkering a bit that location would not work, so I went with the one above.
Mack: Did the guy who installed it for you use the Powerlet wiring? It includes a nice fuse holder which has hole to put a bolt through and secure it. I didn't see a convenient bolt, so the fuse holder is 'floating' under the seat. Doesn't seem to be an issue, but perhaps I am overlooking something.
Dr. D is offline   Reply With Quote
Old 11-16-2012, 09:50 AM   #44 (permalink)
9mmkungfu's Avatar
I have a question. All of my accessories utilize a USB-type of connection. What would be the benefit in installing the powerlet-style outlets as opposed to a direct USB connection such as these offered by 3BR Powersports?
http://www.3brpowersports.com/products.htm
Just curious.
9mmkungfu is offline   Reply With Quote
Old 11-16-2012, 10:34 AM   #45 (permalink)
Just curious.
Powerlet makes the USB harness as well, check out the page: Power Cables - Powerlet Products
The powerlet socket (or commonly referred as BMW style plug) can be used not just with portable electronic accessories, but also with battery chargers (I use Optimate 4 and connect it with my powerlet socket to charge the battery), portable tire inflators, heated gear, etc. Not to mention, these are water resistant too. If you are only looking to charge USB devices, then maybe you don't have to install a powerlet style socket and a USB harness is all you need. Just make sure that whichever harness you buy, it should supply the correct amperage and voltage (most cellphones need 4.75-5.25V @ 950mA-1A). A cheap USB charger can easily brick your device. The quality of cheap USB chargers (or such USB harnesses) is questionable and is a separate discussion altogether. Also keep in mind that every USB charger is different and the same charger cannot be used to charge different USB devices, unless they all require the same charging voltage/amperage.
If I was you, I would install a Powerlet cigarette socket and use a good quality branded car charger to charge the portable electronic devices.
2013 BMW F800GS
1997 Yamaha RX135
1990 Yamaha RD350
Old 11-16-2012, 11:21 AM   #46 (permalink)
9mmkungfu's Avatar
Thanks for the reply. It seems like the powerlet is far more versatile.
Old 11-16-2012, 11:28 AM   #47 (permalink)
FrankoQ's Avatar
This is what I ended up doing.
Fuse box, Battery tender, powered tail bag
1996 Honda VFR 750
Old 11-24-2012, 03:59 PM   #48 (permalink)
doubletap's Avatar
I installed a BlueSea Dual USB Charger Socket on my RR in a fairly stealthy location. Installation was straight forward. I use it to power my phone and Contour HD camera, both of which mount via RAM triple tree ball.
doubletap is online now   Reply With Quote
