Removing GoPro base plates.
Hello,
For any one that is interested if you have GoPro base plates on your helmet or bike & want to remove them & not your paint I have a simple solution.
All that is required is 1meter of fishing line (basic monofilament) double it over & push it as under one corner of the sticky pad with your finger then just use a sawing motion, the fishing line will find it easier to go under than go through the foam & it comes off clean & easy.
I have a black AGV helmet & can't see a single mark from the removal.
Hope this helps anyone that's needs to do this.
Cheers
