DIY - Rear Shock Removal - BMW S1000RR Forums: BMW Sportbike Forum
Go Back   BMW S1000RR Forums: BMW Sportbike Forum > General BMW S1000RR Discussions > S1000RR/HP4 Do-It-Yourself
Old 11-21-2012, 08:20 PM   #1 (permalink)
randomwalker's Avatar
Default DIY - Rear Shock Removal
Here's my step-by-step. Before you begin, start your favorite music:
1. Get bike up on Bursig stand. If you do not have a Bursig stand, try raising the bike up using jack stands under non-foldable rearsets. Otherwise you need to come up with some other method of releasing the tension from the rear shock.
2. Remove front seat, fuel tank cover, raise fuel tank, disconnect the hoses, remove fuel tank and set aside. You may not need to completely remove the fuel tank, but in my case, I'm glad I did because one of the retaining screws had evidently vibrated loose and I would not have seen that had I not completely removed the fuel tank.
2a. Remove the rear wheel (again, may not be necessary, but I needed to do that to prop up the control link...see picture).
3. If you have an after-market exhaust that bolts on to the frame, you will need to unbolt the exhaust.
4. Loosen the upper frame bolt and nut on both sides and remove the lower frame bolt and nut on both sides.
5. Secure the frame with a ratcheting strap and raise it up to make room for the shock to come out.
6. The lower shock bolt is a bitch to reach because the control link is in the way. I used a torx bit (T-50) with a long shaft to loosen the bolt.
7. Remove the upper shock bolt (4) first. The shock will drop down a bit but the lower shock bolt (2) will still not come out because the control link is in the way.
8. Prop up the wish bone (control link) with some tool. I used a mallet.
9. Remove the lower shock bolt, washer and nut.
10. Maneuver the shock out through the room you created under the frame.
11. Voila!
12. Installation is pretty much the reverse of the above...I installed the lower shock bolt first.
13. Torque values: Shock to main frame = 56 Nm; Sub (rear) frame to main frame = 60Nm.
DIY -  Rear Shock Removal-figure-7.jpg   DIY -  Rear Shock Removal-figure-6.jpg   DIY -  Rear Shock Removal-figure-4.jpg   DIY -  Rear Shock Removal-figure-8.jpg   DIY -  Rear Shock Removal-figure-6a.jpg
2011 BMW S1000RR Thunder Gray
Fool me once
randomwalker is online now   Reply With Quote
Old 11-21-2012, 08:23 PM   #2 (permalink)
Some more pictures.
DIY -  Rear Shock Removal-figure-0.jpg   DIY -  Rear Shock Removal-figure-1.jpg   DIY -  Rear Shock Removal-figure-1a.jpg   DIY -  Rear Shock Removal-figure-3.jpg   DIY -  Rear Shock Removal-figure-7a.jpg
Fool me once
Old 11-21-2012, 09:00 PM   #3 (permalink)
RIQUE's Avatar
Thanks for posting Random. My shock will make it here in a few days. Can't wait.
Life Rewards Action.
He who is not afraid is safe!
You get used to speed fast!
Panic is NOT a strategy!
Old 11-22-2012, 12:48 AM   #4 (permalink)
Thanks for posting this. This will come in handy when I go to replace the rear shock
Illusion is offline   Reply With Quote
Old 11-22-2012, 06:13 AM   #5 (permalink)
Welcome. Writing it up helps me understand what I did and hopefully makes it easier to put it all back together..
And don't forget the most important step...reward yourself with a beer!
Fool me once
Old 11-29-2012, 10:57 PM   #6 (permalink)
RIQUE's Avatar
Hey Random, must one remove the rear wheel?
Old 11-30-2012, 01:03 AM   #7 (permalink)
1hotlimo's Avatar
Good post! Thanks
2011 S1000rr
CVMA #65
jr3racing.com
1hotlimo is offline   Reply With Quote
Old 11-30-2012, 05:07 AM   #8 (permalink)
Not necessary. But it helps if you want to prop up the control link (See picture) and it generally gives you some more room.
Fool me once
Old 12-01-2012, 06:53 PM   #9 (permalink)
RIQUE's Avatar
Ok Folks, finished doing my rear shock today and beleive I have some important contributions to the procedure initially posted by Random.
If you don't have a fancy lift or fixed rear sets then what you need to do is remove the ones you have and install them up side down. That way you can use them to support the bike on stands.
I don't recommend removing the rear wheel since I found it was not necessary. Randoms procedure to lift the rear link by proping with a mallet can be overcome by jacking the rear swing arm by rear wheel spools. By doing this removing and installing the bottom shock bolt becomes much simpler and quicker. Some pics for your reference.
DIY -  Rear Shock Removal-dsc_0639-2-.jpg   DIY -  Rear Shock Removal-dsc_0638-2-.jpg
Old 12-01-2012, 07:34 PM   #10 (permalink)
Good stuff.
Fool me once
