DIY for the GothamCycles 55w HID kit Plus LED running lights
A big thanks to GothamCycles. Very responsive to questions and their shipping was lightening fast.
My order shipped on 10/16 and I received the package on 10/17.
NOTE: when I say right side that is the side with the clutch. Left side = the side with the brakes.
Here is a picture of what you get. The LEDs are not included in the kit. If you want them, let them know and pay a little extra.
Before replacing the running lights only:
After replacing the running lights only:
Install is easy on the left side. It was a little involved on the right.
Left side:
A quarter turn counter clockwise and remove the cover.
You will see the running light socket and the wires for it.
Pull on the wires carefully and the socket will come off.
Pull the OEM bulb and store it somewhere. Install the LED bulb. NOTE: test to see if it lights up before you reassemble the socket into the headlight. If not inserted correctly, it won’t light up.
If that happens, turn off switch, pull bulb, reinsert it by turning the base 180 and try again.
Looks good!
to be continued...
