Finally found time to get this done. I searched for a DIY but did not find one with more detailed pictures. Hope this helps others.
Overall... easy install.
here we go...
The current piece
unplug turn signal wire harness.
now to the screws holding the current fender. remove them all.
you end up like this
undo the brackets holding the wire harness to the old fender.
next, just pull on the license plate light. it will just come off easily.
Now to the turn signals. I kept reading people cutting the wires. No need to cut them at all. You only need to cut the wires to the license plate light.
disassemble the turn signals. There is one phillips screw holding the cover.
Once open, just pull on the chrome base to expose the wires behind. unplug the 2 wires (make a note where the 2 color wires go to make sure you put them in the right location when reassembling). Once unplugged, just pull the wires thru the hole to free the turn signal assembly.
now remove the turn lights from the old fender and start putting together the Yoshi pieces. Here is the base plate with the license plate light added.
2 screws hold it. I also added the turn signals to the Yoshi side brackets.
to be continued...
