Home built Radiator protector project! - BMW S1000RR Forums: BMW Sportbike Forum
Old 09-14-2011, 07:20 AM   #1 (permalink)
Beemer's Avatar
Default Home built Radiator protector project!
Being short on cash I decided to build and install my own Radiator guards.
The total cost was about R80.00 (or +-$7.00)
Its really simple to make and install by yourself. (installing I guess being the most tricky part but still simple enough any idiot can do it)
I took some pictures of before and after (sorry forgot to take a pic of the finished product before installing)
I went and bought a normal piece of iron mesh from our local steel suplliers (plain mesh that they use for barbeques, can get them in steel or galvinised steel). I then took the bikes farings off, put the mesh against the radiator and used a marker to trace the shape. Then used a grinder to cut it according to shape and size for both the larger and smaller oil radiator.
After this I treated the mesh with a primer and sprayed it with a can of red engine enamel to fit my colour scheme.
I also got some rubber piping they use for mist spraying in the garden, cut it along on side and slide it over the edges of the mesh as a neat border.
After completing the guards, there are various ways of fixing it onto and infront of the radiator.
Attaching onto the larger radiator I cut out an extra piece at the bottom two corners of the mesh so I could attached it with the two screws that holds the smaller oil radiator.
At the top I just used pieces of wire just to hold it in postion.
With the smaller oil radiator I also just used wire to attached it onto the two sides and bent the mesh around on top and at the bottom so it fit snuggly over the radiator.
All done, just re-attach the farings and stand back and admire your masterpiece
Home built Radiator protector project!-dscn1507-small-.jpg   Home built Radiator protector project!-dscn1504-small-.jpg   Home built Radiator protector project!-dscn1500-small-.jpg
Beemer is offline   Reply With Quote
Old 09-14-2011, 10:13 AM   #2 (permalink)
Nikk777's Avatar
Nice work but will it limit the air flow to the radiator and cause overheating problems? Kinda looks like the flat metal with holes in it vs. the chicken wire/gutter cover type material used in the Cox guards. Also the rubber piping around the edges might look nice and clean things up but I'm guessing it will melt first time the bike comes up to temperature...
Not trying to knock your work, love to see folks doing things themselves... just some constructive critism to make sure all stays healthly with you and your bike. I've been meaning to run to home depot and pick up some gutter covers and make one for my race bike. A rock through the radiator took me out of last year's grand national finals!
Old 09-14-2011, 11:46 AM   #3 (permalink)
kautiongsr's Avatar
looks great.. great pics also
Auto techinteriors
Big Daddy Julio
kautiongsr is offline   Reply With Quote
Old 09-14-2011, 08:22 PM   #4 (permalink)
Looks good.
I may try the same thing as California is doing a lot of loose gravel chip-seal stuff on the mountain roads. Hwy. 155 has no more smooth asphalt west of Greenhorn Mtn., just this stuff that throws rocks up everywhere.
Local mini-market cashier said, "That was as good as it's gonna get." She said it wasn't exactly motorcycle friendly either judging from all the wrecked bikes that stop in there, "but hey, it's cheap!" She said a truck went by and threw a chip-seal rock up into the store (about 15-20 feet).
I'd hate to drag flesh and bone over the stuff.
Mack
Mack is online now   Reply With Quote
Old 09-14-2011, 08:56 PM   #5 (permalink)
CQBRR's Avatar
Good idea...but this guy beat ya!
The $10 solution to protect your radiator and oil cooler
Yes that is a BMW and yes I am glad to see you
CQBRR is offline   Reply With Quote
Old 09-15-2011, 02:27 AM   #6 (permalink)
Beemer's Avatar
No problem, I appreciate your concerns, it was my concerns too.
But, I made the same type of guards on my previous bike, and had no heating problems or rubber edges melting.
I have had these guards on my S1K now for about two weeks and no such problems either. In fact the radiator does not get that hot.
I rather then have radiator guards on than not, as damage to the radiator is a very costly affair.
Old 09-15-2011, 03:07 AM   #7 (permalink)
Beemer's Avatar
Originally Posted by CQBRR View Post
Nice one!
But then again I feel that the holes on yours are a little to big, as smaller stones or debris could still penetrate and damage the radiator.
Thats why I went for the mesh with smaller holes that still allows enough air through.
Old 09-15-2011, 03:10 AM   #8 (permalink)
Beemer's Avatar
Thank you.
