yeah thanks a lot. Got mine and will do the install myself as well. Save some $$$. I actually enlarged the hole in the Yosh bracket so the BMW light wire harness socket fit right through it. On the other end of this harness, I cut off the two license plate light wires and soldered (and shrink wrapped) the BMW wiring harness to the Yosh license plate LED wires.
I am using the BMW LED turn signals (front and rear, P/N:63137714326) and with the rear lights a BMW wiring harness (P/N: 77517728072) is needed to replace the stock harness which has the appropriate connectors where the rear LED plugs into.
