Thought I'd document my first mod. With the cold weather not disappearing fast enough up here in Canada, and the wife being chronically cold-blooded (at least she is on the track), I hooked up a Powerlet plug on her bike to power her heated clothing, and while I was at it, replaced the passenger pegs with Sato Racing Hooks. The hooks are great way to tie the rear of the bike down to the trailer after the passenger-peg-delete.
There are a couple of other Powerlet installs in this section. The Powerlet on the passenger peg location is convenient because you can reach the plug when you're sitting on the bike, and the cord from your heated clothing doesn't have a long ways to go to plug in and it doesn't interfere with your riding at all.
Sorry for the quality of the pictures, it's dark in my garage. When I get the chance, I'll update with some pictures in the sunlight.
These are the Sato Racing Hooks ordered from
Kyle Racing. Very sleek and stylish, no?
This the the Powerlet kit, ordered directly from Powerlet. Get the
Rearset Type-2 Kit, it fits the S1KRR beautifully!
First step is to remove the seat. This is the hardest part of the install. The torx bolts are accessed by pulling the back of the seat cover up a bit. The bolts are quite long, so make sure you don't scratch the paint on the tail as you're removing the seat. Pull the bolts up to the seat to give yourself some clearance.
This is the battery bay, you'll need to disconnect the negative (black) lead first and then the positve (red) to minimize the risk of a short-circuit. Here's a tip: although there is a Phillips head on the battery bolts, do yourself a favour and use a 10mm socket wrench instead. You'll save yourself a stripped screw head.
Now we'll connect the two leads of the Powerlet battery cable to the battery. Positive (red) lead first, then the negative (black last). BMW batteries are nice because the nut is held in place by a plastic tab, instead of falling to the bottom of the bolt cavity where you need to fish it up with a screwdriver. Now is a good time to fit your fuse in the Powerlet fuseholder. When the seat is already bolted on is not a good time to remember that you forgot to fit the fuse in the Powerlet fuseholder...
There is quite a bit of room under the seat so you don't have to be as tidy as I am here, but what I've done is tucked the Powerlet fuseholder to the right side of the bay and I've fished the white plastic Powerlet connector under the seat, like so:
This is way more slack than is needed, as I found out later. You can feed the excess wiring back up into the battery bay.
A couple of torx screws later and the passenger pegs are off! UG-LEE!
