This is barely worth doing a DIY write-up on due to it's simple install. Plus the instructions that come with the seat covers are VERY good. The key is to have a little patience and if you have a spare pair of hands, it helps. More so on the rear seat since it is smaller. I don't run w/rear pegs (nor a passenger) so I'm not sure I'll keep the rear on all the time or stick w/the rear cowl instead.
Let me know your opinion on which looks better:
Rear Cowl ----OR---- Rear Matching Seat
Tools Needed:
- Small Flat Screw Driver (to remove the staples)
- Needle Noose Pliars (to remove the staples)
- Manual or Electric Staple Gun - I actually found that the manual worked better for this application.
- Some larger paper clips - the big black ones (this helps hold the new cover to the seat while you staple it in
- Philips Screw Driver - Needed if you're doing the rear seat
- 10mm socket/ratchet - Needed if you're doing the rear seat
Rear Seat:
1) Remove Seat and Hardware from seat (rear lock and front hardware) This requires a philips screw driver and a 10mm socket respectively.
2) Remove strap from rear seat (10mm bolts hold it on)
3) Remove staples holding upholstery on
4) Install Luimoto Cover and follow the instructions provide. (The paper clips definitely come in handy!!)
Front Seat:
1) Remove Seat
2) Remove staples holding upholstery on
3) Install Luimoto Cover and follow the instructions provide.
The fit and quality are outstanding. Haven't gone for a ride yet (20*F out
Again, let me know which combo you think fits the bike better (Luimoto front w/rear cowl --OR-- Luimoto front w/matching Luimoto rear)
