Changing the front brake pads on the s1000rr is easy
tools needed
13mm socket
torque wrench to 28 ft-lbs or 38 Nm
I am changing to the Carbone Lorraine c55 front brake pads
(need four boxes, two pads in each box)
1st need to loosen the front caliper bolts
once you have the caliper off you need to take the pads out by pushing in the metal bracket and pulling out the pin which can be done by hand
once you have all the pins out put in your new pads in and bracket and push the pin threw
once you have you pads in, install the caliper and tighten the bolts to 28 ft-lbs or 38 Nm
and enjoy your better brakes
