Shaving the seat down - BMW S1000RR Forums: BMW Sportbike Forum
Old 05-24-2010, 01:08 PM   #1 (permalink)
Avboden's Avatar
Default Shaving the seat down
Cross posting this here for my father.
A replacement stock seat for the S1000RR is pretty reasonable (all things considered) so I brought one in to ""lower" it, by removing some of it's foam. It appeared to me that there was about 1 1/2 inches in the main seat area that could be removed. Risk would be a rock hard seat, properly contoured and lowered. Benefit would be a comfortable seat, properly contoured and lowered. Can always send it out to a seat maker and put in a thin gel pad, and do it in proper material (leather?). Meanwhile, removing the stock seat staples everywhere but the very back of the seat gives lots of access and a sharp knife will do the job. Note well this stuff shreds and makes a mess ! I have put the seat back on the bike, for now without re-stapling the cover, just to get a feel for the "fit". Will update when I get to ride hopefully tomorrow. (BTW: I am 5'7" and like a slightly lower seat than stock).
He went out and rode with it today and said there is 0 noticeable difference in comfort cushiness but he's a full inch lower or so.
Avboden is offline   Reply With Quote
Old 05-25-2010, 01:47 PM   #2 (permalink)
gely's Avatar
Please post a picture with the cover on.
gely is offline   Reply With Quote
Old 05-25-2010, 04:16 PM   #3 (permalink)
kismetcapitan's Avatar
I like that seat, and it seems simple enough to do. I only worry that, although being lower may be more comfortable for 95% of my riding situations, this time around, I want to be high enough to really yank the bike around corners and bring my cornering skills up a couple of notches.
Old 05-25-2010, 04:47 PM   #4 (permalink)
gely's Avatar
Shaving the will not effect the geometry of the bike.
Old 05-29-2010, 04:00 AM   #5 (permalink)
Avboden's Avatar
update from my father
"The stock seat actually has at least 1 1/2 inches to shave down, especially in the front, and can be narrowed and reshaped for a smoother contour easily. Worked out well. My sit on the bike is much better and my comfort likewise.
For now I am recovering with the stock seat cover. This is the interesting part. The stock seat material is very thin and very flexible. Hence it contours easily to the new shaping. BUT: it shows all the defects in the foam and any remaining ridges, etc.
I am going to try a couple new techniques on the foam, including power sanding with a course grit and maybe even heating to see how it melts. I will run some of that on the trimmed off pieces.
Reminds me of the commercials and shows " do not try this at home. This was done by a professional idiot..."
None the less, I recommend anyone that wants to lower their seat and sit lower in the tank by a couple inches to try this. Especially if you are in a big city with a professional seat maker, they can always salvage the stock seat with a good gelpad and cover material of your choice."
sorry no pics recovered, but you should get the idea.
Old 05-29-2010, 07:45 AM   #6 (permalink)
true, but it will affect handling because this 70kg mass called the rider has just moved down over an inch. But being mobile, can probably maneuver around it well; hell, rearsets have a lesser but similar effect in how and where a rider can shift their weight onto the bike.
Old 05-30-2010, 12:22 PM   #7 (permalink)
Avboden's Avatar
update, sounds like this foam is a real PIA to work with. The suggestion is to just get it done at a seat maker.
"I had previous seats done by Riche's in Seattle and loved them. The choice of material was great and the finish detail incredible. I just wanted a fast go at this one to see if it was a worthwhile effort. I will probably finish up this riding season on this selfmade deal and then send it off for a real pad and cover during our winter.
BTW, I watched some of the foam shaving at Riches and the most handy tool is a long electric knife, like the kind to cut turkey. I really butchered mine with what I thought was a sharp enough kitchen knife.
Remember the foam on this seat really shreds easily and makes quite a mess, so do it without the spouse/significant other home if possible. Not to sure how the dogs digest the stuff, either, so you may want to keep them outside !"
