Gilles Frame Slider Installation - BMW S1000RR Forums: BMW Sportbike Forum
Old 03-29-2010, 07:47 PM   #1 (permalink)
Default Gilles Frame Slider Installation
I ordered a set of Gilles Frame sliders from Shift-Tech. Looked at Woodcrafts and a few others but I liked the way the Gilles sliders compress on impact. It was almost too easy to install them.
Tools needed:
8mm allen for installation
T45(might be a T50) Torx for bolt removal
Parts. 2 Sliders, 2 sleeves, 2 spacers, 2 bolts. Pretty simple.
Left side, 1 bolt, pretty easy to find
Installed. The longer bolt and the short washer spacer are used on this side.
Right side, 1 bolt. This side required the longer spacer to avoild cutting the body work, but the shorter bolt because the slider is actually shorter
Installed
Done
They're a little on the big side... but they might make me less nervous about the really straight up side stand and the possibility of this thing getting blown or knocked over.
ToddACimer is offline   Reply With Quote
Old 04-03-2010, 02:45 AM   #2 (permalink)
S1RR's Avatar
Thumbs up
Man, they are pretty big. But as long as they do there job, thats all that matters in my book.
I've never seen Gilles engine sliders before. I always tend to use R&G's.
Garage:
S1RR is offline   Reply With Quote
Old 04-03-2010, 11:53 AM   #3 (permalink)
Glad you like it, Todd.
Nice part is also that you can just replace the outer puck if you do ever go down and don't have to buy a complete new set.
Gilles offers every part individual .
Here once R&G vs. Gilles .
Gilles Frame Slider Installation-slider-left-right-copy.jpg   Gilles Frame Slider Installation-right-left.jpg
Shift-Tech-Carbon is offline   Reply With Quote
Old 04-03-2010, 07:30 PM   #4 (permalink)
firearmsdoc's Avatar
Default Torque specs???
Todd,
I have the same sliders but haven't installed yet. Do you happen to have the torque specs for those two engine mounting bolts for the Giles sliders?
Thanks!!!
firearmsdoc is offline   Reply With Quote
Old 04-04-2010, 03:49 AM   #5 (permalink)
S1RR's Avatar
Originally Posted by firearmsdoc View Post
Todd,
Thanks!!!
I know you have Gilles sliders. However, as a rough guide, R&G do not provide torgue values as the use of compression sleeves inside the bobbins enables adequate tightening of the bolts and the bolts will stay secure. For peace of mind use some Loctite or similar. Do not put bodyweight behind tightening as this can damage the bolt and even strip threads in your engine, leading to expensive repair work. In any situation DO NOT EXCEED 40 Nm (29.5ft/lbs) of torque.
Garage:
Old 04-04-2010, 05:35 PM   #6 (permalink)
If I recall correctly the instructions said 45 Nm
Old 04-05-2010, 02:58 AM   #7 (permalink)
///ACS330Ci's Avatar
I thought it was 56 NM in the Gilles instructions . . .
///ACS330Ci is offline   Reply With Quote
Old 04-05-2010, 03:40 AM   #8 (permalink)
S1RR's Avatar
Wow now boys, hold on there……your gunna start stripping threads with those numbers.
Garage:
Old 04-05-2010, 03:33 PM   #9 (permalink)
BMW Motorrad specs
"Cylinder head to frame
Cylinder head, left, to frame, M10 x 50 - Initial torque, 10 Nm - Final torque, 56 Nm
Cylinder head, right, to frame, M10 x 50, with taper elements - 56 Nm"
Old 04-05-2010, 05:57 PM   #10 (permalink)
BMW Motorrad specs
Thanks for clearing that up.
