Hotbodies rear hugger - BMW S1000RR Forums: BMW Sportbike Forum
Old 07-10-2011, 05:43 PM   #1 (permalink)
Thumbs up Hotbodies rear hugger
I just installed a new Hotbodies color matched rear hugger for my Thunder Grey S1kRR. Three bolts, 2 minutes to swap out the OEM black plastic piece. It extends further back over the rear tire by a few inches, and has a small vented cowl instead of the larger opening on the OEM piece. The right side has a clean looking flange that secures the ABS cabling for the rear wheel against the swingarm. Coupled with the HB undertail, it gives the rear end a nice clean color matched look! Still looking for a slip on, but since I like the look of the stock, and the power:weight ratio is already overkill, no big hurry
Hotbodies rear hugger-hugger-left-side.jpg   Hotbodies rear hugger-hugger-right-side.jpg   Hotbodies rear hugger-hugger-top-left.jpg   Hotbodies rear hugger-hugger-right-rear.jpg
AZDocG is offline   Reply With Quote
Old 07-10-2011, 06:06 PM   #2 (permalink)
1K Bimmer's Avatar
Nice hugger, went to HB's website but not showing a hugger for the BMW S1RR
1K Bimmer is offline   Reply With Quote
Old 07-10-2011, 06:07 PM   #3 (permalink)
Deadsp1's Avatar
I like how they have done the break lines going under the hugger,but id like to see a carbon one ;') Do these come with the spacers so it doesn't rub on the swing arm?
Deadsp1 is offline   Reply With Quote
Old 07-11-2011, 12:24 PM   #4 (permalink)
If you look closely in the pix, the plastic is depressed around the bolt mounting holes, so it only contacts the swingarm at those 3 points. The rest of the assembly floats ~2mm over the surface.
Old 07-11-2011, 04:43 PM   #5 (permalink)
moman's Avatar
I thought the cutout in the OEM was there for clearance with the larger tray to house the ABS valve
moman is offline   Reply With Quote
Old 07-12-2011, 02:05 AM   #6 (permalink)
Godzilla's Avatar
No its not, not sure why it is there
Old 07-12-2011, 10:13 PM   #7 (permalink)
New release on this part and they have not posted on site yet. I kept bugging them past year when they'd come out with a hugger
Give them a call and inquire wrt availability for your color choice.
Old 07-12-2011, 10:15 PM   #8 (permalink)
Aerodynamic drag reduction in either case (large opening or the vented opening)...
Old 07-14-2011, 06:13 PM   #9 (permalink)
K12
K12's Avatar
Looks great AZ they just finished up photoshoot yesterday and should be online soon.
Hotbodies rear hugger-img_0001.jpg   Hotbodies rear hugger-img_0009.jpg   Hotbodies rear hugger-img_0012.jpg
K12 is offline   Reply With Quote
Old 07-31-2011, 02:49 PM   #10 (permalink)
Salem_HN's Avatar
i'm still waiting for rear Hugger on their online store :|
E A T R I D E S L E E P ... !
Salem_HN is offline   Reply With Quote
