Originally Posted by Loomis
In the Pic looks look u dont have the small bolt holding the Chain adjuster in place?
No, I think this is the correct installation...
The silver head of the mounting bolt is clearly visible on the left. If you mean the black screw holding the adjuster bolt captive, it's flush with the retaining nut on the bottom right of the adjuster body and wouldn't be visible from this angle.
At least I
hope it's the correct installation. It's exactly the way I installed mine!
Oddly, my original washer does not obscure the markings on the middle of the axle carrier.They are justmvisible above and below the washer.
For those of you not using a washer, have you noticed if the axle nut is galling the face of the axle carrier?
