I've fitted a complete set of Ilmberger Carbon Fairings to my bike. Everything bar the Hugger which is from Harris.
The Top Tank Panel to Side Panels needs a little push together as you do up the screws & the Side panels under the Seat are a little twisted, so need a push/pull to line the screw holes up. I did notice my side panels were rubbing my tank, where your knees are. I put some rubber/foam on the inside of the panels so it sits on the metal bracket. This holds the panel clear of the tank and stiffens it all up. The Belly Pan need pulling tight to the side panels also to close up the gap before tightening the screws.
Not cheep stuff but on the whole its good quality (cheeper than BMW HP stuff). Oh and better quality than Harris stuff.
I have a mix of road & race parts on my bike, so I could fit the full Race Belly Pan. It all looks the same & is all very light & thin.
Carbon Fibre has a quality of not stressing like metal or abs platic, so should take the few stresses you put in it fitting the stuff. It does though not yeild (or stretch) like Metal or Plastic, pushed to far it will just snap!!
Well pleased with mine. Got a deal from Twin Shacks here in the UK, cheaper than Sandbar Composites.
