LED running light install problem please help - BMW S1000RR Forums: BMW Sportbike Forum
Old 05-23-2011, 08:58 PM   #1 (permalink)
Default LED running light install problem please help
i installed the 9 wedge style bulb, and i am getting the lamp code error, i insatlled and load resistor and the bulbs still stay on at 15 %power when bike is off and code is showing what am i doing wrong.....?
1fastrr is offline   Reply With Quote
Old 05-23-2011, 09:54 PM   #2 (permalink)
Mine stay on for about a minute and then will shut off. You probably have HID headlight or both lights HID? If they shut off after a minute or two don't worry about it.
If they stay on all the time that is a problem. They are backfeeding through the wire harness and there is no fix. Possibly a diode would keep it from doing it but not sure. You should get the "error free" type of bulb. They are more expensive but work better.
Old 05-24-2011, 11:55 PM   #3 (permalink)
my dub ass, didnt pierce the wire on the resisitor install, all good now!
Old 07-04-2011, 04:00 AM   #4 (permalink)
1000RR Bahrain's Avatar
I have the HID for the low beam, and installed these LEDs for both front parking lights
http://cgi.ebay.com/ebaymotors/2x-T1...item23112cb17f
as u said because i have the HID, these LEDs stay on for a minute or so after shutting the bike off and then they shut off alone and when they r on while the bike is shut off they are not 100% @ full power
sometimes i get the lamp code error after starting the bike but after few seconds it clears out they look really good with the low beam HID
Last edited by 1000RR Bahrain; 07-04-2011 at 04:03 AM. Reason: Putting the right link
