Please help asap please - BMW S1000RR Forums: BMW Sportbike Forum
Old 05-07-2011, 04:17 PM   #1 (permalink)
Default Please help asap please
i installed 2 t-wedge t10 pushin lights for the front lights near the headlights. when i put one in its fine, if i install both i have the "LAMP!" on the guage. how to i resolve this.
http://www.s1000rrforum.com/forum/at...1&d=1304799431
1fastrr is offline   Reply With Quote
Old 05-07-2011, 06:12 PM   #2 (permalink)
It's probably due to a lower resistance in the new bulbs... the Can-bus thinks you have a light out so it's putting a message on the dash. Throw the old ones back in and see if the error goes away - then you will have confirmed the new bulbs have the wrong resistance.
Old 05-07-2011, 06:16 PM   #3 (permalink)
brown1000's Avatar
I have the same led lights, & I use a load resistor. I bought it from
Super Bright LEDs - Brake Light, Turn Light and Tail Light Bulbs
2010 S1000RR Acid Green Edition/ For Sale
2007 GSXR-1000 Track
brown1000 is offline   Reply With Quote
Old 05-08-2011, 01:51 PM   #4 (permalink)
old ones work fine and lamp code off,
BROWN --- did this resolve the issue?
Old 05-08-2011, 01:54 PM   #5 (permalink)
ere are 3 of them, which one did you install, and do i need 1 for each side?
Old 05-08-2011, 10:15 PM   #6 (permalink)
brown1000's Avatar
I ended up taking those led's that you have out, because after being in there they will start to burn the inside of the headlight. I went with the led's that just shine forward. As far as the Load resistor, you will only need one for both front maker lights. You only need to hook up one side, & that will be enough to trick the computer in to thinking both lights are working.
Old 05-23-2011, 08:56 PM   #7 (permalink)
lamp code is still on and the leds wont shut off when bike is off....
