Spidi is well known for their outstanding one piece leathers but they also make an excellent back and chest protector call the
Defender. Particularly unique when compared to some other back protectors on the market, the Spidi Defender is comprised of mostly low-friction materials on its outer-facing sides. It won’t grab or pull on your leathers from the inside which makes moving around on the bike easier and the impact armor even less noticeable under your leather suit. A wide swath of armor on the back is CE Level-2 certified and it comes with a chest protector that can easily be positioned to fit almost any shape. Light in weight and slim, the Defender provides a significant level of impact absorbing protection for any brand of leathers without compromising ergonomics.
Available in small – X-large, call TJ at 866.931.6644 x 817 for more information. You can also send a note to FORUM at RIDERSDISCOUNT dot COM with SPIDI DEFENDER ARMOR in the subject line and be sure to let us know what size you need so we can get back to you right away.
Built to easily fit under your riding leathers, the Defender Back & Chester Protector kit’s low profile can easily be adjusted at the shoulders and waist for a comfortable fit.
A lightweight composite material is used as impact absorbing armor for a back protector that surpasses CE Level 2 performance standards.
Armor components are surrounded by air vents and a mesh liner for maximum comfort over a wide range of conditions.
