Straight off the peg, the
Spidi T-2 WindPro leather suit feels like a well-seasoned suit thanks to its excellent cut and a 1.2-1.3mm thick high-quality cowhide chassis. Every aspect of the Spidi T-2 suit was designed with the rider in mind with ideally-placed flex panels and neoprene collars for maximum comfort. This is, in fact, Spidi’s second generation in their T series with improvements being made to the CE-certified protectors as well as the cut of the suit to enhance rider protection and comfort. Provisions for a
Spidi Warrior back protector and
Spidi Warrior Chest Protector are also included to augment the impact absorbing properties of the suit.
For more information and expert sizing assistance, call TJ at 866-931-6644 ext 817 to get yours today. You can also send email with SPIDI T2 LEATHER SUIT in the subject line to FORUM at RIDERSDISCOUNT dot COM and we’ll get back to you right away.
Spidi T-2 Wind Pro one piece leather suits are available in two colors, black and white, as shown here …
… or red, white and blue.
Spidi uses Keprotek stretch panels in areas that are the least likely to contact the ground in a fall. Between these and the supremely supple leather, the suit is flexible and remarkably comfortable.
In areas that require stretch panels, but would be unsafe to use anything but leather, Spidi employs elasticized panels to permit a useful range of movement. Here’s a close-up view of the left shoulder flex panel.
These panels are created by attaching leather to stretched Lycra sheets via rows of stiches and they can be stretched up to twice as long as their resting configuration.
Elasticized leather panels are also used just above the knees …
