LighTech Chain Adjusters for BMW S1000RR - BMW S1000RR Forums: BMW Sportbike Forum
Old 03-17-2011, 10:19 AM   #1 (permalink)
Default LighTech Chain Adjusters for BMW S1000RR
LighTech Chain Adjusters not only provide a trick look to the rear end of your motorcycle but they’re also a precision instrument for adjusting your motorcycle chain. A straight, properly tensioned chain will last longer saving you money in the long run. What sets LighTech chain adjusters apart from other brands on the market today is their click detent adjustment scheme which is akin to that of suspension adjustment knobs. A scale is laser-etched on the unit in a high-contrast manner, making chain adjustment quick and easy, even in low light. In this way, you can count clicks audibly and verify adjustment so you can be confident you’re doing things right. As an added bonus, you won’t have to deal with the OEM chain adjuster blocks falling out of place every time you go to swap out tires. And, these chain adjuster blocks are manufactured to tight tolerances which removes axle slop in the rear, further enhancing precision chain adjustment.
LighTech aftermarket motorcycle parts are not yet available on our website. To order a set of LighTech BMW chain adjusters, call TJ at 866.931.6644 ext 817. You can also email us, send those to FORUM at RIDERSDISCOUNT dot COM with LIGHTECH S1000RR CHAIN ADJUSTERS in the subject line and we’ll get back to you right away.
Each LighTech chain adjuster kit comes complete with all necessary hardware and simple installation instructions with torque specifications.
A bracket is attached to the back side of each chain adjuster to securely wrap the device solidly in position against the swingarm.
Each axle block rides on a rail that is positioned between the main chassis of the adjuster and the swingarm.
A precision metric scale is etched into the axle adjuster itself. This, along with a pair of notches that are machined into the axle block itself, provide for instant chain alignment reference.
As mentioned, the adjuster bolts have a detent mechanism within them so you could simply count the clicks when making adjustments to one side and then repeat that on the other for quick, easy chain alignment.
Old 03-17-2011, 10:23 AM   #2 (permalink)
S1000RR ROB's Avatar
iv got them in blue and they look absolutely the dogs nuts on a motorsport
Old 03-17-2011, 10:25 AM   #3 (permalink)
Depths_of_Mind's Avatar
dammit.. I ordered these like 2 weeks ago from another company... GRRR... woulda rather went with you RD
Old 03-17-2011, 10:46 AM   #4 (permalink)
Triple Threat's Avatar
Please email price, also interested in one of the black Lighttech bolts axle bolts
Michael
Old 03-17-2011, 10:47 AM   #5 (permalink)
Dshred's Avatar
How much for the black ones?
Old 03-17-2011, 10:51 AM   #6 (permalink)
I want!! How much are they going for in black?
mcmpr42669 is offline   Reply With Quote
Old 03-17-2011, 11:38 AM   #7 (permalink)
Default LighTech Chain Adjuster Color Options
Here's a look at all of the colors we have available for S1000RR chain adjusters from LighTech.
Choose wisely.
Red LighTech chain adjusters.
Blue LighTech chain adjusters.
Gold chain adjusters for the BMW S1000RR.
Old 03-17-2011, 11:43 AM   #8 (permalink)
Dshred's Avatar
Right back at ya.
Old 04-14-2011, 04:52 PM   #9 (permalink)
Here's a photo of LighTech chain adjusters on the S1000RR.
Old 04-14-2011, 05:46 PM   #10 (permalink)
Hello,
Please let me know what the pricing is.
Best regards,
Greg
glewis01 is online now   Reply With Quote
