Samco Sport Hose Kits are number one in the paddock for performance radiator hose applications thanks to their high-quality components and smart, durable design. Samco Hoses are handmade with SAE J20 spec silicone, not a less-expensive silicone that is filled with components that add bulk but do not enhance performance. The British manufacturer employs a full-time laboratory staff to develop, design and test new applications and new materials in ways that you can’t always see. For example, their direct-replacement hose kits use their SamTek lining that withstands vibration and heat over a long period of time in the most extreme conditions – perfect for your motorcycle. On the inside, hoses are bent precisely to reduce flow resistance and increase cooling efficiency for more reliable engine performance.
We have these kits in stock and ready to ship for the BMW S1000RR in red, white, blue or black colors. And don’t forget to ask about an
Oetiker Stepless Hose Clamp Kit for installing these Samco hoses on your BMW S1000RR.
Call TJ at 866.931.6644 ext 817 to get your hose kit today. You can also email us if you have any questions; send those to FORUM at RIDERSDISCOUNT dot COM with BMW S1000RR SAMCO HOSE KIT in the subject line along with the color you want and we’ll get back to you right away.
Samco hoses are pre-bent for each specific application. The hoses will retain their shape thanks to a specific fabric weave pattern within the hose itself.
We use Samco Hoses on our own
BMW S1000RR project bike not only for their reliability but also their good looks!
Inside, a blue SamTek silicone hose lining is used. 12 years in the making, this material easily withstands the high temperatures and vibrations of a racing engine for a lifetime of reliable performance.
Aftermarket coolant hoses from Samco are a direct replacement for the OEM lines and require no cutting or bending to install. They go in place in the exact same manner as your bike’s original hoses.
Samco uses high-quality fabrics to reinforce their hoses. These fabrics are oriented in a specific manner to resist swelling and expansion that would otherwise inhibit coolant flow and ultimately reduce cooling system efficiency.
Choose your color wisely. Samco hoses are purpose-built and will retain their good looks without warping or fading. You can expect these to last as long as the bike you put them on!
