Graves S1000RR Full Titanium Exhaust System - BMW S1000RR Forums: BMW Sportbike Forum
Old 02-14-2011, 05:46 PM   #1 (permalink)
Default Graves S1000RR Full Titanium Exhaust System
Eliminate the massive weight of the OEM catalytic convertor on your BMW S1000RR with a Graves Full Titanium exhaust system! Crafted to the same standard as the championship-winning exhausts used on their AMA Superbikes, the S1000RR Graves full system makes it possible to unlock additional horsepower from your BMW. The exhaust provides a weight savings of almost 20lbs while delivering a smooth, throaty note that’s pleasing to the enthusiast’s ears. Each exhaust system is made with mandrel-bent titanium tubing and finished off with a carbon fiber sleeve muffler.
We do not yet have Graves exhaust systems on our website. For more information, call TJ at 866.931.6644 ext 817 or send an email to FORUM at RIDERSDISCOUNT dot COM with S1000RR GRAVES EXHUAST and we’ll get back to you right away.
Every S1000RR exhaust comes complete with assembly instructions and an optional exhaust hanger bracket for those wishing to eliminate the OEM passenger pegs.
Old 02-14-2011, 05:46 PM   #2 (permalink)
Primary headers feature a balancer pipe between #2 and #3 cylinders for a broader spread of torque.
Every header is matched the cylinder head with CNC-machined aluminum spigots. These are tapered to permit maximum exhaust flow efficiency.
Aluminum brackets provide the needed support for attaching the headers to the engine.
Titanium welding takes great skill and it appears that the craftsmen at Graves Motorsports have this technique down perfect.
A single lambda sensor located on the down tube from the muffler is provided with this system. It’s perfect for attaching a self-tuning kit like the Bazzaz Z-AFM or Dynojet AutoTune.
This S1000RR muffler uses Graves’ “Everlast” exhaust packing which is designed to withstand the high exhaust pulse environment common in performance engines. It provides a unique tone and holds up longer than conventional packing materials. The carbon fiber muffler itself is covered at both ends by a titanium end cap.
Old 02-14-2011, 05:57 PM   #3 (permalink)
