For maximum safety, proper tire pressure is critical to the performance of your motorcycle - so get a gauge made by a company known for quality, Motion Pro. Their newest digital tire pressure gauge has the same dimensions and the same pressure control as their reliable analog pressure gauges but uses a high-precision digital pressure sensor that is accurate to within 1% at 77°F. Powered by a single 9V battery, this pressure gauge has a nominal service life of 1,000 tests before the battery needs to be replaced. This is accomplished with power saving circuitry that automatically shuts the device off after three minutes. And unlike some digital pressure gauges that require the user to “reset” the instrument to take a reading when setting tire pressure, this device continuously measures pressure with no user input required – just like an analog pressure gauge.
These instruments are not yet available on our website. For more information, contact TJ at 866.931.6644 ext 817 or send him an email; FORUM at RIDERSDISCOUNT dot COM with MOTION PRO DIGITAL TIRE PRESSURE GAUGE in the subject line and he’ll get back to you promptly.
The Motion Pro Digital Tire Pressure Gauge is the most accurate tire pressure instrument made by the company and features a resolution of 0.1 psi. A vinyl storage pouch is also included with this gauge.
The blue anodized aluminum body is machined from billet and houses a single, easily modulated bleed valve to help you quickly set your motorcycle tire pressure.
If you’ve ever used a lesser gauge that required some gymnastics just to get to the valve stem on the wheel, you’ll be thankful for the dual-swivel action of this digital tire pressure gauge’s 18” hose.
360° swivels are mounted both, at the air chuck
and on the bleed valve assembly which makes reading the display while accessing any valve stem hassle free!
Working in low-light conditions is no problem with the backlit display.
This precision tire gauge reliably reads pressures between 0-60 psi. It can be zeroed with the push of a button and will also display pressure in whatever unit you prefer: Psi, BAR, KG/CM2 or kPa - making it suitable for a wide range of applications.
