Ogio Rig 9800 Motorcycle Gear Bag - BMW S1000RR Forums: BMW Sportbike Forum
Old 11-08-2010, 01:48 PM   #1 (permalink)
Default Ogio Rig 9800 Motorcycle Gear Bag
The Rig 9800 gear bag replaces the previous Ogio 9800 as the company’s premier gear bag. It has everything you need to keep all of your motorcycle gear in one place, ready to go when you need and surrounded by a semi-rigid 600D PVC/420D Dobby Poly PVC shell that’s guaranteed to last for life. To protect the gear within, foam is placed between the inner and outer paneling and Ogio uses their proven SLED (Structural Load Equalizing Deck) – a hard exoskeleton on the bottom, to impart rigidity and extra durability to the bag. For ease of handling, a pair of large wheels at one end of the SLED chassis is complimented at the other by a retractable Pullman handle for easy rolling while strategically-placed grab handles on the top and sides of the bag make it easy to pick up when you’re carrying a heavy load. Measuring 16” tall by 17” wide and 36” long, there’s plenty of room for all of your motorcycle gear and then some. In fact, we’ve found these bags useful for cross-country trips that had nothing to do with motorcycles – just throw all your gear in and go!
Currently available in Stealth black only, call TJ at 866.931.6644 ext 817 for more information. You can also send email enquiries to FORUM at RIDERSDISCOUNT dot COM with OGIO RIG 9800 in the subject line and we’ll get back to you right away.
The Rig 9800 in Stealth black.
The included removable helmet cradle keeps your helmet separated from everything else.
Looking inside the Rig 9800, there’s plenty of room for your helmet, boots, gloves, your leathers and other gear. Inside the zippered top section, you’ll find room for a change of clothing or additional moto gear.
