CRG Folding Brake & Clutch Levers - BMW S1000RR Forums: BMW Sportbike Forum
Old 10-25-2010, 04:41 PM   #1 (permalink)
Default CRG Folding Brake & Clutch Levers
CRG folding levers are built to the same exacting tolerances of the company’s own Roll-A-Click levers that have made them famous all over the world with the added survivability of a break-away feature. Precision machined from solid billet 6061-T6 aluminum then hard anodized for lasting beauty, these levers look good on any bike and function flawlessly. Unlike OEM and many aftermarket levers that don’t fold, if your ride turns into a bad trip, you’re more likely to retain front brake or clutch function thanks to the CRG lever’s folding design. A heavy-duty ball-spring detent hinge mechanism prevents the CRG lever from folding accidentally during normal use, yet it has just enough give to help prevent it from breaking off in a crash. Not only are you more likely to ride away from a crash without a broken lever, but thanks to their break-away function, you’re also more likely to avoid expensive damage to your BMW’s master cylinder or clutch perch after these are installed on your bike.
CRG Roll-a-Click folding levers are a relatively inexpensive investment when compared to lost time at the track or waiting for a tow truck while stranded out on the road because of a broken brake or clutch lever.
Available individually or as a pair to replace your brake or clutch levers on ABS-equipped BMW S1000RR models, we also have these in non-folding versions with either shorty or standard-length levers. Folding levers come with black or gray levers while non-folding units come in black, gray or gold colors.
CRG levers are not yet on our website; call TJ at 866.931.6644 ext 817 to order. You can also send email to FORUM at RIDERSDISCOUNT dot COM with the subject line BMW CRG LEVERS and be sure to specify if you want brake, clutch or both levers, the color you’d like and standard, shorty or folding lever types.
A pair of gray CRG folding levers for the S1000RR with CRG’s trademark red adjustment tabs. These adjusters allow you to easily move the lever toward or away from the handlebar for a perfect reach.
Built to the same spec of CRG’s Roll-a-Click levers with the addition of a folding function.
The folding mechanism in action.
CRG levers are a direct drop-in replacement for the BMW’s levers and are assembled using high-quality fasteners.
All CRG levers, rearsets and other components are manufactured entirely in the USA.
Non-folding levers are also available in gold …
… or black.
Old 01-27-2012, 10:22 PM   #2 (permalink)
bens1000rr's Avatar
pm price please
bens1000rr is offline   Reply With Quote
Old 01-28-2012, 06:30 PM   #3 (permalink)
Old 03-08-2012, 10:18 PM   #4 (permalink)
Hello, can you please PM a price for the CRG folding levers in black for ABS version of 2010 bmw s1000rr shipped to 60020?
dantera333 is offline   Reply With Quote
Old 03-08-2012, 11:54 PM   #5 (permalink)
muttang's Avatar
TJ- Price to Brisbane Australia please.... Not sure on colour yet but probably black..
Thanks
muttang is online now   Reply With Quote
Old 03-09-2012, 09:33 AM   #6 (permalink)
Sending PM's now
Old 03-09-2012, 08:37 PM   #7 (permalink)
pm price pls. 2012
Mario_1 is offline   Reply With Quote
Old 03-09-2012, 11:04 PM   #8 (permalink)
PM Price Please..... 2012........
Kindred is offline   Reply With Quote
Old 03-10-2012, 10:16 AM   #9 (permalink)
Sending PM's now
Old 03-10-2012, 11:53 AM   #10 (permalink)
Gamisou's Avatar
pm price on 2011 plz!
2011 Thunder Grey
Gamisou is offline   Reply With Quote
