Motion Pro Motorcycle Hex Axle Tool - BMW S1000RR Forums: BMW Sportbike Forum
Old 07-19-2010, 12:47 PM   #1 (permalink)
Default Motion Pro Motorcycle Hex Axle Tool
Perfect for swapping out the front wheel on most late model sport bikes, the Hex Axle Tool from Motion Pro has 17mm, 19mm, 22mm and 24mm hex keys on it that snap into any 3/8” square drive. This one tool will suit many bikes and costs less than buying all four hex bits individually. It’s also useful on many swingarm pivots and on other large hardware when the time comes for a complete tear-down.
If you’re a serious rider, this belongs in your toolbox; call TJ at 866.931.6644 ext 817 to have him send you this motorcycle axle tool. As always, we never charge extra for shipping in the contiguous USA!
Two version of this tool are available:
Made from 7075-T6 aluminum, the Superlight Hex Axle Tool is good for light use where torque specifications are no greater than 90ft-lbs. Retail $39.95; get it for $32 shipped to your door.
For shop use, this chromium molybdenum steel Hex Axle Tool, while heavier than the Superlight model, is rated for torque applications up to 150ft-lbs. Retail $29.95; get it for $25 shipped to your door.
Perfect for swapping out the front end on your motorcycle.
