LiFePO4 batteries, like the Ballistic Performance EVO2 are nothing like conventional lead-acid batteries. They’re lighter, smaller and significantly more efficient than the technology employed in conventional motorcycle batteries which have their roots in the year 1859! This means that, while conventional battery chargers can be employed to quickly top off Ballistic EVO2 batteries, to truly exploit their energy potential, you need a specialized charging system.
Enter the Battery Management System (BMS): Intelligent Digital Balance Charger from Ballistic Performance Components. It’s the only device specifically engineered for Ballistic Performance EVO2 batteries.
The Ballistic BMS plugs directly into the latest generation Ballistic EVO2’s BMS port, allowing you to fully charge each individual cell within the battery itself via balance mode charging. In this way, the voltage of each individual cell is precisely controlled for maximum output power performance. Furthermore, the BMS charger has four function modes: charge, fast charge, balance charge and storage charge which should cover the requirements of just about every rider out there.
Advantages of the BMS over conventional timed chargers:
Know exactly how much charge each cell within the battery contains
Conditions battery by balancing cells with an even charge throughout
Batteries that are periodically balance-charged can be expected to last twice as long as batteries that are only charged by your machine’s charging system
Ballistic BMS Intelligent Battery Chargers are perfect for riders that demand the most performance from their machines. And, unlike other lighteweight battery brands that don’t tell you anything about charging their batteries and instead, force you to buy their EXPENSIVE charger - the Ballistic BMS is
reasonably priced with an MSRP of $79.99.
These battery chargers are not yet available on our website. To order, call TJ at 866.931.6644 x 817 to order, or send a note to FORUM at RIDERSDISCOUNT dot COM with BALLISTIC BATTERY MANAGEMENT SYSTEM in the subject line and we’ll get back to you right away.
Each Ballistic BMS kit comes complete with everything you need to get the most performance out of the latest generation of Ballistic Performance EVO2 Batteries.
To balance charge your Ballistic Performance Battery, a direct plug-in harness is included with this kit.
All critical charging information is visible when the device is on.
For those that have previous generation Ballistic batteries, conventional charging functions are also available with the BMS charger.
