With a brake light and turn signal flasher all built into one design,
Dynamic
Moto
Power Powergrid integrated LED taillights have the kind of brightness that will get you noticed! What sets DMP Powergrid kits apart from other aftermarket integrated taillights is their lens designs which are specifically tailored to reflected the most light possible outwards via a mirrored LED surface finish. That, and the high-quality polycarbonate lens housing features a topography that further enhances light output so other road users are better able to see you. The wire harness employs a factory-type brake light connector and you simply need to re-use the OEM hardware for installing a DMP taillight kit. You’ll be able to eliminate your OEM turn signals too so you can easily clean up the rear end of your bike.
To assure proper functionality, all DMP light kits are tested at the factory, twice: once during production and again before final packaging. Easy-to-understand installation instructions are also included with each kit.
Kits are available with either smoked or clear lenses for all 2009-2011 BMW S1000RR models.
DMP light kits are not yet available on our website, for more information, call TJ at 866.931.6644 x 817 or send a note to FORUM at RIDERSDISCOUNT dot COM with DMP POWERGRID S1000RR INTEGRATED TAILLIGHT in the subject line, include the model/year of the bike you own and whether you want a clear or smoked lens and we’ll get back to you right away.
DMP Powergrid integrated lights combine the brake like and turn signal functions into one clean design that follows the OEM shape perfectly.
A powerful grid (Powergrid) of light emitting diodes are arrayed in a manner that compliments the specially-shaped polycarbonate lens housing for a brilliant display that will get you noticed by others on the road.
